![]() | Home > Technical > Webasto Help |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
sounds like its the Webasto pump goosed to me.
Mine dont whine, the only noise you get is combustion and the fuel pump Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
There are two fans - one for air and the other circulates the coolant.
If the coolant pump falls, the Webasto should detect an overheat and shut down, but you will hear the air fan running whilst it does so. The coolant pump is available from a number of places - I got a genuine one from Germany via eBay for half the price of a genuine one in the UK. One way to check if the water pump is working is start the Webasto on a cold engine and then feel the coolant pipes whilst it runs. On mine the pipes got very hot and then the Webasto shut down. New pump sorted it out immediately. Dave Green Goddess - 1998 Defender 110 300tdi |
NorTD5 Member Since: 07 Nov 2013 Location: Kristiansand Posts: 26 ![]() ![]() ![]() |
Thanks for the tips - if it ever stops snowing, I will go out and check the coolant pipes. Thankfully it is easily accessible. In the meantime, I guess I will have a look for a pump on Ebay and locally.
Cheers, Mark |
Just like you described Dave - the pipes got hot by the Webasto unit, but were stone cold a foot away. Time to start shopping for a new circulation pump!
Cheers, Mark |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 ![]() ![]() ![]() |
Thanks for the tips - if it ever stops snowing, ill swop the rain for snow
Thought so! If you prise up the centre black cover (where the cable from the water pump goes into) you can unplug the electrical connector from the pump and then apply 12V to the pins, just to make sure. I got my replacement from eBay from a seller called autoteileostde. There is one listed here. I reused the original water pump electrical connector and just joined the wires. I found it easier to clamp the coolant and fuel pipes to remove the entire thing and replace the pump on the workbench. Whilst I was there I found the stainless steel exhaust piping had split in several places, so I ended up replacing that too. Dave Green Goddess - 1998 Defender 110 300tdi |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
One more thing to check on a TD5:
The expansion pipe from the radiator to the expansion bottle must have a one way valve it it or the webasto sucks air into coolant pipes meaning it air locks and leads to the same fail conditions (webasto gets hot but fails to circulate). Make sure the valve is in place and it hasn't failed. |
Ordered, and as a special bonus, my better half is going home to London this week, so we can get it delivered there and avoid extra shipping and Norway's handling charges and import taxes. Thanks again, and I will update on fitting in a couple of weeks or so, depending on the weather...
Mark |
Just read the message from Phoenix. Will check that tomorrow after work - watch this space for a circulation pump for sale if I find a problem!
Mark |
Mark,
If you go into my gallery, I have just uploaded some english instructions for a Webasto on a TD5 (might be the same as you have already). Check out page 6 where it shows photos of the valve installed, photo 13 & 14. If there is a valve problem, it doesn't have to be the webasto one you use. I used one similar to THIS and it did the job nicely. Like I say, one more thing to check ![]() |
If the non-return valve fails you'll often hear a strange gurgling when the Webasto is running on it's own. The effect on my Td5 was that the Webasto worked, but it didn't get very warm.
As I said, test the existing pump with 12V to the pins on the connector. It's quiet quiet, but you can feeling it working if you reach down to it. PS If you get the +ve and -ve the wrong way round when testing it, it won't run either. Dave Green Goddess - 1998 Defender 110 300tdi |
No sign of a non return valve on the overflow, so I will fix that - it looks to be an easy fix and I am sure I can find a one way valve locally. Is 8mm the right size, Phoenix?
Also no sign of any vibration in the circulation pump, when the unit is running cold, although I did not set up a separate 12v supply - it is -4C and snowing lightly out there so I did not want to hang around for too long. Not sure I am tough enough for this climate! ![]() Should be able to sort the valve out this weekend, so will have a few days before the pump comes back from England to try it out... Thanks again for the advice. Mark |
Just a quick update - two weekends of going to every motor factors in this area of Norway has failed to get me a one way valve, so this is going to wait until my brother comes out next month and will bring one with him...
In the meantime, I have a bright and shiny new circulation pump, but am resisting the temptation to put it in until I have tried the cheaper fix. As the Webasto definitely does the job of helping the engine up to temperature faster, this job can wait a bit, and I can focus on the electrical gremlins that appeared when a couple of warm days melted all the snow... ![]() |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 245 ![]() ![]() |
I havent seen this one way valve on other Td5s I have looked at in Norway, but then again I wasnt looking for it either.
Was the webasto fitted new by the norwegian importer ? Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
