Home > Maintenance & Modifications > Front wheel arch liners
mk1collector
I'm looking into getting the Gwyn Lewis front mud flap extender kit, but looking at the pics of them fitted there seems to be a big gap in the original front wheel arch liner where the extra liner in the kit fits. Having looked at my wheel arch liner (110 td5 csw2004) the wheel arch liner seems to come a lot further down so I'm not sure if the kit will fit. Does anyone have any experience of this or understand what I'm on about Rolling with laughter before I ring them direct?
Ray
Post #299065 15th Jan 2014 2:50pm
SailingTom
Hi Ray
I've got them fitted on mine, they slide up partly behind the inner arch so nothing can get round the back I suppose Smile
Its all clear on the instructions you can download though.
Hope this helps, did you go for the wide mud flap brackets aswell?
Cheers Tom Defender puma dormobile camper
Post #299075 15th Jan 2014 3:32pm
MartinK
I fitted them - mainly to protect the front outriggers, and to reduce the crap being thrown up under the vehicle. A reasonably good mod for the price I thought, easy to fit too Smile Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #299076 15th Jan 2014 3:42pm
mk1collector
Cheers for the info but I think my arch liners are different to the ones that allow this kit to be fitted. The open bit of the liner that the shield in the kit covers has an extra moulded bit on my liner like this
So I'm not sure if the kit will fit.
Post #299086 15th Jan 2014 4:42pm
SailingTom
Yes your right it does look different, have you got a lower angle looking up shot? then I can go out and let you know.
If not might be worth giving them a call as seem very helpful. The other option might be cut a bit of the plastic out, although from those pictures it doesn't look a 'bit'
Very Happy
Just went out and had a look and it is very different. I reckon you'll have to give them a ring and see or a bit of trimming first.
cheers Tom Defender puma dormobile camper
Post #299102 15th Jan 2014 5:34pm
I've got them fitted on my defenders, simple, sensible mod.
But, did you know, some td5's have a "filled in" wheel arch as standard
Post #299105 15th Jan 2014 5:40pm
mk1collector
That must be what I have. @sailing tom I'll try and get a better pic in the light but it sounds like I may have to just get the bracket to move the mud flap going on what bpman has just posted.
Post #299106 15th Jan 2014 5:43pm
SailingTom
Yeah looks like your right, either just the mud flap and leave the bit exposed or some cutting then. Id be tempted to just mount the mud flap. Just a tip I found it easier to fit with the nuts on the inside of the arch and made a fiddly job much easier Defender puma dormobile camper
Post #299107 15th Jan 2014 5:47pm
mk1collector
Thumbs Up thanks for the tip
Post #299115 15th Jan 2014 5:54pm
