![]() | Home > Td5 > Passanger side foot well - hole |
Probably the hole for the Aircon piping. Stick up a picture and we can say for sure.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
It is below the heater box by about 8-12" 1999 Defender TD5 110
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Yup, aircon pipe hole.
There is a large grommet that will fit in there. I've not got the part # to hand at the moment, but have one in my 110. |
Sounds like the one to me. Will break out the measuring stick and see what size it is. 1999 Defender TD5 110
Lewisgregory8 Member Since: 17 Sep 2012 Location: Durham Posts: 395 ![]() ![]() |
is it not to let the water in?
Where else can you have a ready made, easily accessable from both sides method of passing wires and cb cables to the outside world
This one?
![]() Click image to enlarge As said above, it's for aircon and it seems the people on the production line can't be bothered to put many grommets in the vehicles without aircon :roll: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
That's the hole. When it stops raining, I will be out to measure the hole and get a bung - unless someone else knows the measurements? 1999 Defender TD5 110
kevin1 Member Since: 07 Sep 2013 Location: west sussex Posts: 12 ![]() ![]() ![]() |
looking for the same part got a part number 345140 but says for heater ,it is 50mm does anyone know if this is the correct part
I ended up putting a Vw bung in it that I had hanging around and then sealed and dynamated over the top so I'm not sure of size or part number, sorry.
just did a search and 345140 is the grommet required
Looks to me that the aircon was removed at some point from your defender. Smaller hole that is lower down is for the drain pipe.
