Home > Td5 > Passanger side foot well - hole
excossack
1999 TD5
I've got a hole (its been there since I got the car) in the foot well on the passenger side that can be seen from the engine bay. At the mo its got some masking tape on it from the inside, but I feel a bung would be better.
Whats the hole for and is there a part available to seal this hole up ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #298645 14th Jan 2014 10:56am
geobloke
Probably the hole for the Aircon piping. Stick up a picture and we can say for sure.
Post #298653 14th Jan 2014 11:13am
excossack
It is below the heater box by about 8-12" 1999 Defender TD5 110
Regards
John M0VAZ
Post #298667 14th Jan 2014 11:53am
Yup, aircon pipe hole.
There is a large grommet that will fit in there. I've not got the part # to hand at the moment, but have one in my 110.
Post #298682 14th Jan 2014 12:15pm
excossack
Sounds like the one to me. Will break out the measuring stick and see what size it is. 1999 Defender TD5 110
Regards
John M0VAZ
Post #298706 14th Jan 2014 1:16pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
is it not to let the water in? Rolling with laughter
Post #298725 14th Jan 2014 3:25pm
JWL
Where else can you have a ready made, easily accessable from both sides method of passing wires and cb cables to the outside world Whistle
Post #298727 14th Jan 2014 3:31pm
mk1collector
This one?
As said above, it's for aircon and it seems the people on the production line can't be bothered to put many grommets in the vehicles without aircon :roll:
Post #298741 14th Jan 2014 4:34pm
excossack
That's the hole. When it stops raining, I will be out to measure the hole and get a bung - unless someone else knows the measurements? 1999 Defender TD5 110
Regards
John M0VAZ
Post #298780 14th Jan 2014 6:52pm
kevin1
England 1999 Defender 90 Td5 SW Rutland Red
looking for the same part got a part number 345140 but says for heater ,it is 50mm does anyone know if this is the correct part Question
Post #298801 14th Jan 2014 7:22pm
mk1collector
I ended up putting a Vw bung in it that I had hanging around and then sealed and dynamated over the top so I'm not sure of size or part number, sorry.
Post #298812 14th Jan 2014 7:48pm
kevin1
just did a search and 345140 is the grommet required
Post #298821 14th Jan 2014 8:03pm
geobloke
Looks to me that the aircon was removed at some point from your defender. Smaller hole that is lower down is for the drain pipe.
Post #298995 15th Jan 2014 10:13am
