Home > Tdi > Pre 200/300 tdi engine reliability?
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I'm looking at a rebuilt 90 which has galv chassis and lots of work done to sort doors, suspension, bulkhead, interior refurbed etc, 1990 yr model.
The engine is the original unit, a pre 200/300, even though it's a tdi, 115k miles, serviced with all filers etc.
I don't mind being down on power as I've recently sold a n/a diesel and it never really bothered me as I don't intend doing long journeys, mainly local short runs, but are there any issues to look for that I should know about?
Post #298261 13th Jan 2014 9:01am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Assuming its the 2.5TD then its not the finest engine ever made. Having said that, if its survived this long then it will probably be one of the good ones. If you can find Defender 200 tdi then it will drop straight into it when that engine does pack in. If the rest of it is in good nick then dont let the engine put you off, its far easier to change a engine than a bulkhead or the chassis.
Pete.
Post #298271 13th Jan 2014 9:52am
landys1
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Santorini Black
Above post my thoughts exactly when I bought a 1989 90 last year for knocking about in. The one you're looking at will be a 2.5 TD for that year (assuming original engine!), allegedly not the best engine, but the one in mine has been great, no problems with it (Ok, it's not a Puma!), but fine for trundellng about in, uses no oil/water, and no leaks!! Very Happy
The reason I bought this was cos the rest of it was very sound - great chassis/bulkhead, and everything worked on it, only needed a bit of cosmetic tidying. As Zinke says, the later 200tdi will drop straight in if the TD engine ever goes - but while its still working good, I'll leave as it is! 1959 Series 2 Ragtop
1989 SWB Stationwagon
1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work)
2011 Puma 90 2.4 XS
Post #298305 13th Jan 2014 12:37pm
Lambley
Thanks both for the above replies, it is a TD engine that's fitted, which is the original unit, after speaking to the person who's done the chassis exchange the chassis etc, he said he'd used the vehicle himself as a run-around before doing the chassis, new door bottoms, bulkhead etc etc, almost everything is perfect on it, just as I'd have done it, but the engine is the weak link, seems a shame to have gone to all that trouble and then not put a 200 or 300 tdi engine in.
Anyway, still thinking about it before parting with my hard earned!
Thanks again.
Post #298561 14th Jan 2014 12:11am
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
If it was me I would defo fit a tdi twice the power with better mpg worth thinking about Wink Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #300654 20th Jan 2014 7:27pm
