![]() | Home > Puma (Tdci) > Passenger wiper. |
See if the wiper arm moves with the motor off. Would mean the drive teeth are broken.
You'll have to get at the drive box behind the wiper spindle. Remove the backplate and withdraw the wiper spindle. Sometimes it will rotate 180 degrees to fresh gear teeth. Otherwise you''ll have to replace the box. ![]() |
Frenchy90 Member Since: 17 Apr 2013 Location: Surrey Posts: 29 ![]() ![]() ![]() |
Thanks for the reply. To replace the box does that involve removing the whole dash board?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
It sure does, it's not too bad a job as long as you are careful about not loosing the screws ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Yes its a dash out job.
You dont have to remove it fully from the vehical. I had to replace the whole system on a mates puma a few months back. A spindle seized up which caused the motor to over load & blow ![]() You will swear alot but can be done by just pulling dash out enough. Just work your way round removing the screws etc ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
