Home > Puma (Tdci) > Passenger wiper.
Frenchy90
England 2007 Defender 90 Puma 2.4 SW Zambezi Silver
Passenger wiper.
Hi all
I was making my way through Denmark today and my passanger wiper arm made a loud clonk and stop moving. The drivers side works still. The passanger arm wasn't returning as normal before and there was a build up of rust. Can someone advise me on how to go about fixing this DIY style.
Many Thanks.
Post #297217 9th Jan 2014 6:08pm
Laurie
See if the wiper arm moves with the motor off. Would mean the drive teeth are broken.
You'll have to get at the drive box behind the wiper spindle.
Remove the backplate and withdraw the wiper spindle.
Sometimes it will rotate 180 degrees to fresh gear teeth.
Otherwise you''ll have to replace the box.
Post #297226 9th Jan 2014 6:22pm
Frenchy90
Thanks for the reply. To replace the box does that involve removing the whole dash board?
Post #297228 9th Jan 2014 6:39pm
grafty99
It sure does, it's not too bad a job as long as you are careful about not loosing the screws Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #297239 9th Jan 2014 7:37pm
Dieselhead
Yes its a dash out job.
You dont have to remove it fully from the vehical. I had to replace the whole system on a mates puma a few months back. A spindle seized up which caused the motor to over load & blow Mad
You will swear alot but can be done by just pulling dash out enough.
Just work your way round removing the screws etc Thumbs Up Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #297340 9th Jan 2014 10:42pm
