- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Sventheviking
Thought I would share this in case others have the same problem. My Reversing light failed, main dealer had it for two days, finally found the wire had rubbed through near the switch where it apparently runs along the top of the gearbox and in turn this caused damage to the switch. Originally they said it wasn't covered under warranty but a check of the policy exclusions and a quick call to the warranty technical department confirmed it was covered and the dealer couldn't charge me . Got to watch em!
8th Jan 2014 8:19pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
