Home > Td5 > Headlights gone..
Gareth
Headlights gone..
Driving home from Nottingham to Stockport this evening, stopped for fuel. Came to set off after filling up, no headlamps Evil or Very Mad Side lamps, dash lamps all OK, spots come on with headlamp flash.
So after searching the forum, going to take the switch out to test it. Any other likely failure points? 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #296997 8th Jan 2014 7:00pm
Almost certainly the switch unfortunately. Darren
Post #297000 8th Jan 2014 7:12pm
landy andy
Switch mate. Cut wires and join as temp, get you home.
Unless both bulbs, or both fuses gone but very unlikely.
Andy
Post #297014 8th Jan 2014 7:42pm
Gareth
Ok, its not the switch. It looks pretty new. Got home on the sidelights. Shorting the red and the blue does not turn the lights on. Shorting the red and brown puts the sidelights on.
It looks like it might be the dip switch thats at fault, its very loose on the steering column, and the it looks like the plastic casing is cracked. Its a bit difficult to see inside the metal surround.
Any tips for getting the steering wheel off to get a closer look? It won't budge.
Censored down now, so leaving it until tomorrow. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297033 8th Jan 2014 8:58pm
Ken B
Either a puller tool which is best or brass mallet with the nut at end of the thread giving the colum a thump whilst pulling the wheel Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #297042 8th Jan 2014 9:17pm
landy andy
As above.
I loosen the nut, (not remove it). Pull like Censored and give the centre shaft a good smack with copper mallet.
Did you have dim dip on yours?
Andy
Post #297044 8th Jan 2014 9:21pm
Gareth
No it does not have dim dip.
Looking at wiring diagram now, and the fact that the main beams come on with the flash function only, but neither dip or main work in the normal position, could be the relay. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297077 8th Jan 2014 10:14pm
NoDo$h
There isn't a relay for the headlights, which is why the switches tend to burn out.
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #297112 8th Jan 2014 11:25pm
Gareth
There is a relay that energises the headlamp switch when the ignition is on. However, even if I short the wires to the switch, the light still do not come on. So looking like its the dip/main/indicator/horn switch unit.
Only problem is, I can't get the feckin steering wheel to budge so I can take it off the vehicle. Shall look again tomorrow. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297117 8th Jan 2014 11:36pm
landy andy
You should not need to remove the wheel to be able to test the switch, just remove the cowl. I think from memory there is a blue cable that fits on a pin that can come off giving no lights.
Got a spare set of switches here, should you need a temporary set Thumbs Up or a photo
Andy
Post #297142 9th Jan 2014 8:14am
Gareth
Sorted Thumbs Up
It was the dip/indicator/horn switch that had self destructed. The contacts were very burnt. Got a new switch today, and all back to normal.
One final question - When fitting the new switch, what is the correct way to align the self cancel indicator ring (the blue ring that engages with the back of the steering wheel) There is 2 ways to do it, 180 degrees apart! 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297382 9th Jan 2014 11:16pm
landy andy
Been ages since I played, but it has a small mark on it that should point towards indicator stalk from memory.
Did you manage to get wheel off ok?
Andy
Post #297385 9th Jan 2014 11:20pm
Gareth
Ahh ok. It has a small plastic tab that can be at the top or the bottom. I have self cancel on left hand turns, but on right hand, the indicator cancels as I turn the wheel to the right, so I guess I have it 180 degrees out. Job foir tomorrow.
BTW, I had thought the headlamps were getting a bit dim for a while now, and this is obviously a warning of pending destruction of the switch. Now they are nice and bright once again. 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297387 9th Jan 2014 11:24pm
landy andy
There is a very small arrow moulded into it as well. The arrow needs to point to the switch
Post #297388 9th Jan 2014 11:26pm
Gareth
Fantastic, cheers Andy. Cool 2021 Defender 110 X-Dynamic HSE D300 MHEV
Post #297389 9th Jan 2014 11:27pm
