Home > Puma (Tdci) > 110 diff locker
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
110 diff locker
Hello,
I had a detroit truetrac on my last 110 300tdi and I'd like to fit one on my Puma rear axle. Does anyone know where could I get one?
And if anybodie has the ref. of a rear ARB. Bow down
Thanks.
Post #29462 10th Apr 2010 10:03pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
http://crowndiffs.co.uk/diffs.html#det_true
Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29471 11th Apr 2010 6:44am
Apynala
Thanks for this adress,
If I understand the ARB are the same since 2003 for 110, the P38 and for Wolf Shocked
Is it the same for Truetrac?
Does anyone put one Truetrac on the rear axle of his Puma 110?
Thanks.
Post #29662 12th Apr 2010 9:10pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I'm going to put a KAM locker on mine when funds allow.
http://www.kamdiffs.com/four_by_four.php?l...fflock1701 One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #29670 13th Apr 2010 12:10am
MK
Thanks.
REAR RD57 OR RD138
TT SAME (MAKE SURE FITS THE REAR AXLE)
I WOULDN`T SPEND $ ON A REAR TRUETRAC (IMHO) Puma 110" SW
Post #29672 13th Apr 2010 12:34am
willy eckerslike
Alan,
Why the Kam over the ARB, are they cheaper or just better or easier to fit. I had a look at them as well but was a bit put off by the welding which meant I had to get someone to fit it for me. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29675 13th Apr 2010 6:15am
Apynala
MK wrote:
REAR RD57 OR RD138
Confused
Why ?
I thought that one truetrac on front and one on rear were enought for me for sand, mud and rocks. I thought that diff locks needs heavy duty half shafts and flanges but truetrac no.
Do you think rear ARB is better than 2 truetrac ?
Thanks.
Post #29686 13th Apr 2010 8:31am
willy eckerslike
If you follow the link you can read the differences and recomendations, I personally haven't bothered up rating my half shafts for my rear ARB, but I don't enter competitions or drive the shafts too hard. Whistle The truetracs are cheaper and they lock to 70% and are proven to be reliable.
If you drive on sand alot then do you air down your tyres, if so then you will need a compressor, so the ARB compressor can be dual use, i.e. it will work your Difflock and provide air for tyres etc. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29687 13th Apr 2010 8:37am
MK
Apynala wrote:
MK wrote:
REAR RD57 OR RD138
Confused
Why ?
Thanks.
Well, this could be a long story, but on uneven terrain with twisted axles I would say full lockable diffs would work better. I heard for flat sand and ice TT are enough. I do not rock crawling and connect the arb before things become ugly. In this way I have managed to keep my std halfshafts.
Mk Puma 110" SW
Post #29690 13th Apr 2010 9:10am
Cibit
How much air is needed for the activation of the ARB lockers. I now have a compressor on the warn powerplant. Would I need a resevoir too?
Willy did you fit your locker yourself mate? And when you back on terra firma? There are some lanes near Hawes I want to do Thumbs Up 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #29693 13th Apr 2010 11:18am
willy eckerslike
Cibit, lets do em next week, off today but stuck in Aberdeen doing exams til friday.
The locker was fitted with assistance from Pete Bell's Mate, but is straight fwd once it is built into the diff, best to buy one already in the diff then you can take it out when you sell. The warn will supply more than enough air as is, though you would need a solenoid to regulate the air to the diff etc I'll show you mine if you show me yours. Thumbs Up
If you look in devon 4 x 4 forum there are a few complete ones for sale, or a full set including compressor for 1k which is a bargain Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29696 13th Apr 2010 11:49am
Apynala
Mk
Hello,
I'm happy to know that ARB can be use with OE halfshat and cleverness. I've already a compressor (flash air) but I just want to use it for the tires. It quickly becomes hot when using.
If I decide to fit an ARB I surely put another compressor.
thanks.
Post #29741 13th Apr 2010 5:48pm
alantd
willy eckerslike wrote:
Alan,
I like the look of the ARB too. I wanted to uprate my half shafts and I was tempted by the KAM ones. I guess that led me to look at their uprated, lockable diff too. I agree that having one that you don't need to weld the case would be a bonus. One that started out as a 2.4 TDCi 110 XS
Post #29767 14th Apr 2010 5:32am
