Home > Puma (Tdci) > Maintenance Check Sheet for 2.2 Diesel
Ok so I've seen the Check Sheet for the 2.4D. Both the miles and km versions have been posted on this forum; but I've never seen one for a 2.2D.
I'm assuming that it may be no different in terms of the actual applicable tasks but it would be nice to see a copy. Anyone know any reference places to get a copy from for free?
Post #296801 8th Jan 2014 9:38am
Defender-Stu
Not sure if this is what you mean?
Stu
Post #296808 8th Jan 2014 10:38am
Yes - that's the version for the 2.4D.
I'm looking for the 2.2D version. As said previously, I'm expecting it to be susbstantially the same but it would just be good to confirm that with an actual copy of it.
Post #296820 8th Jan 2014 11:07am
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
I would also be interested in a 2.2 version if anyone has an electronic copy.
Does anyone know how to get the information onto LR electronic service record system, if the service was carried out by an non dealership garage?
Post #296952 8th Jan 2014 5:48pm
Well I've been ringing around for prices today and several dealers have muttered about the dpf making the service more expensive, so maybe the new Check Sheet makes reference to a particular activity for this?
Post #296958 8th Jan 2014 6:01pm
Naks
Surely the maintenance check sheet would be the same on both models? Only the specific engine oil grades would differ, but the service items would be the same? --
Post #296974 8th Jan 2014 6:55pm
astoltz
South Africa
Not 2.2 but this is what I did with the 2.4 schedule
http://4x4community.co.za/forum/showthread.php?t=158042 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #297711 11th Jan 2014 3:48am
OK so having just had my 1st service, I thought I'd share the new version sheet for anyone else looking for a copy:
and also a copy of the six year anti-performation warranty annual inspection:
Post #301132 22nd Jan 2014 9:48am
adamatdraycott
United Kingdom 2014 Defender 90 Puma 2.2 SW Corris Grey
With regard to the corrosion sheet, i take you haven't had your truck undersealed... but would LR make note if you had underselaed that an inspection couldn't take place due to non-approved underseal covering everything?
Could undersealing a Defender from new void corrosion warranties purely because they are now unable to insoect the under body?
Not that its going to stop me
Post #301189 22nd Jan 2014 1:32pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Thank you Supacat!
I've been scouring the web for this as I try to decide about signing up to Land Rover's Service Plan. Topix is ok if you have a log-in, which I don't.
Cheers, Angus
Post #360265 26th Sep 2014 11:42am
I thought it might be worthwhile to post an update. Mines been in for it's 2nd service and there's some revised paperwork.
The main difference that's immediately apparant is that changing the differential oil has changed from a 48k/4 year cycle down to every 2 years. I woner what's happened to cause that change?
Post #422214 9th May 2015 2:11pm
lohr500
So my MY12 XS 110 Station Wagon is coming up for it's third service and has just 10k miles on it.
The warranty expires towards the end of June.
It has been in for some warranty work this week including the oil pump replacement.
As I see it, I have just had the oil and filter changed for free as part of the pump change Laughing
Looking at the A service and other docs Supercat has posted, apart from a few basic checks, topping up the transfer box and dropping the diff oils, there is not a great deal to do.
I'm reaching the conclusion that I should just :
Take it in to get the corrosion check done and the book stamped. No idea what they charge for that.
Book it into a discount MOT place to get the MOT sorted (before the warranty runs out just in case there are any issues)
Check the transfer box oil level
Change the diff oils
Grease any propshaft joint nipples (if they still have them)
And carry out the other checks on the service list.
Only down sides I can see are that LR might be less helpful if something goes bang in July and the vehicle could be worth a bit less without a full dealer service history come the time to sell.
I've asked a couple of stealers if they can do a bargain basement service given no need for oil and filter change, but unless it comes in really low cost I just can't see the sense in paying through the nose for a dealer stamp in the service book.
Any thoughts?
Also, would you drop the transfer box and gearbox oils at 10k as well, or is that just overkill?
Post #423870 15th May 2015 8:38pm
ericdavisoz
Australia 2013 Defender 110 Puma 2.2 SW Baltic Blue
I was able to log into Land Rover's Online Service History - https://osh.landrover.com - enter my VIN, and then download each of the service check sheets up to 200000km.
Post #763543 15th Mar 2019 5:50am
Maxime
Germany 2008 Defender 90 Puma 2.4 SW Santorini Black
What a great link, thanks. Unfortunately my Defender was apparently delivered to Russia and is not eligible for this service Crying or Very sad
Post #763554 15th Mar 2019 8:37am
nicam
2015 Defender 110 Puma 2.2 USW Aintree Green
Useful service history site - would be even better if the information was accurate!!!
Checked on mine and it says one service was done at Hunters in Kings Lynn - and its never been within 50 miles of there!
As the computer guys say - "Rubbish In - Rubbish Out" Don`t drive faster than your angel can fly!
Post #763641 15th Mar 2019 5:05pm
