Home > Maintenance & Modifications > Bonnet protection |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Pretty sure there is only one manufacturer of one piece Puma bonnet chequer plate and that is Mammoth.
Available from forum sponsor MPS Trading (SGH) We've got it fitted to the FCX 130 and it seems good quality |
6th Jan 2014 4:36pm |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 |
No Problems with Mammouth, excellent kit. I fitted my wing cp with foam gaskets.
6th Jan 2014 4:39pm |
Mammouth is good quality. You get gasket supplied and I used Sikaflex to seal up afterwards. If you're bonnet's not fooked now after drilling 28 holes to fit it it will be....
The photos are long gone but here was my fitting guide.....
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Jan 2014 4:44pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Just got a Mamouth 4x4 trading Pumatech bonnet cover. They don't come with foam (I'm sure the last one did.. Go Beyond????)
Anyways I drilled more holes (and countersunk them) to get a better fit. Nothing that wrong with the standard fitment I just wanted it better Oh and I swapped the bolts for stainless ones |
6th Jan 2014 6:09pm |
Andrew,
Mine came with foam gaskets and stainless bolts? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Jan 2014 7:07pm |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 |
I love the one piece from mamoth but at the cost I can replace my bonnet for a colour matched one and have change for some ale after so I havent bought it. It is a very pricey item but I do want one lol
6th Jan 2014 7:11pm |
£270 and you can get a bonnet swap? Where from?
6th Jan 2014 8:02pm |
Yes Andrew it has foam
6th Jan 2014 8:18pm |
Thanks for the nod...... Right I best get on the phone then
7th Jan 2014 10:31am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
That is a great looking 90....everything on the front seems to, "fit". Pickles. |
7th Jan 2014 9:29pm |
