Home > Maintenance & Modifications > Headlight warning buzzer |
Did you wire it to be activated when the doors are opened? An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
5th Jan 2014 3:10pm |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 |
Yes dead easy.
One wire to side light switch live , one to ignition live (cancels beeper when ign on / engine running) and other to door pin switch ground. you can do it less than an hour if your left alone. Unlike me at work yesterday "can you just have a look at this for me" ARRRRGGGGGGGGGGGGG ! If your interested the part number is durite 0-562-00 12 volt lights on warning buzzer (but it does bleep not buzz) |
5th Jan 2014 3:52pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
I bought one from vehicle wiring products HERE but it's on my to-do list so I have no idea what noise it makes. http://defender90xs.blogspot.co.uk/
5th Jan 2014 4:34pm |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 131 |
That would be handy!
6th Jan 2014 1:16pm |
Don't know about you guys but on my LHD it's hard to get the key out (big fob) without turning the lights off... Tell someone you love them today because life is short.
But shout it at them in German because life is also terrifying and confusing... |
6th Jan 2014 1:56pm |
Practically undoable actually... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
6th Jan 2014 2:08pm |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I fitted a sound card from CPC, bought as a kit, which has a range of sounds. Choose the siren option. Incorporated a relay so that if I get out of the car, to say open a gate, the alarm doesn't go off, (yes I know that's illegal but we all do it don't we?). Could be louder but it has saved me more that once. One point: the standard alarm, AS10, gave a permanent red light on the dashboard (door open), which was cured by putting a diode in the feed from the door switch to the AS10.
This should be a standard feature. Merlin |
6th Jan 2014 6:07pm |
I always find that my mouth acts as a warning just after I catch my thumb on the light switch when turning the ignition off. Don't make old people mad.
We don't like being old in the first place, so it doesn't take much to us off. Richard |
6th Jan 2014 7:44pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
I find the switch is in the way with lights on , as regards windscreen get them to take it out completely and run sikaflex all the way round thats what i asked the windscreen chap to do when i needed a new one fitting no leaks at all now |
6th Jan 2014 8:05pm |
I know this is veering dangerously but LR finally removed my windscreen frame, completely "renovated" it (after 2 1/2 years!) sealed a new (working) heated screen in and put the whole lot back together and painted it. I hope to God that's the last of my leaking problems... but I'm not holding my breath... Tell someone you love them today because life is short.
6th Jan 2014 8:36pm |
I put power to the warning buzzer from Vehicle Wiring Products and recorded the sound for anyone who is interested:
https://www.dropbox.com/s/8phmtlns3bty7w1/PTT-20140108-WA0007.aac Turn the volume down as the recording is quite loud. Keep in mind this will be hidden away in the dash so the noise will be attenuated. http://defender90xs.blogspot.co.uk/ |
8th Jan 2014 8:33pm |
Yep - that'll work Tell someone you love them today because life is short.
8th Jan 2014 9:22pm |
Finally got round to fitting my lights on warning buzzer and writing it up.
Details here: http://defender90xs.blogspot.co.uk/2014/03...uzzer.html Warning! contains sarcasm. http://defender90xs.blogspot.co.uk/ |
26th Apr 2014 8:41pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
What year were these warning buzzers introduced as standard?
19th Aug 2017 9:56am |
