Home > Puma (Tdci) > Part found under the front carpets - what is it? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
Hi all
While routing the GPS cable under the front passenger seat in the landy, I found this metal part under the carpets. Anyone know what it is/does, and whether I should be worried or not? Click image to enlarge *edit: added proper pic URL -- Regards, Nakkiran Last edited by Naks on 12th Apr 2010 8:26am. Edited 1 time in total |
12th Apr 2010 7:24am |
I can't see any images..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
12th Apr 2010 8:20am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Oh No Your Fuffle Valve holder has become detached, I'm afraid it's terminal Naks infact you're
K Nak ered Original Member Pie n Pea Club. 110 HCPU Tipper |
12th Apr 2010 9:10am |
yaya. |
12th Apr 2010 9:22am |
Sorry Naks.................. I've no idea what it is does look like it's had a bashing. Can't think of anything internal where that could have come from. Original Member Pie n Pea Club.
110 HCPU Tipper |
12th Apr 2010 9:28am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
Can't see the image either One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
12th Apr 2010 10:54am |
how about this one: Click image to enlarge |
12th Apr 2010 10:56am |
Really looks like a valve seat out of a gate valve, but why that would be in the car I don't know, does it split by levering just under that top rim with a sharp screwdriver Original Member Pie n Pea Club.
110 HCPU Tipper |
12th Apr 2010 10:57am |
Not sure, haven't tried. Most likely explanation is that someone working on the car left it there by mistake. Maybe even from the factory |
12th Apr 2010 10:58am |
Never seen that before. Why would it be under the carpet? Was it just loose?
Maybe something fell off the production line One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 |
Clutch release bearing, perhaps?
Intresting if it is as it should be in the bell housing and not under the carpets Joe NB: the truck would not be going if the release bearing is not in place!! JLS 'El Pepe Flamenco' |
12th Apr 2010 12:42pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
it's a warm air/cold air valve 2.4 90 XS
12th Apr 2010 1:50pm |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
Must have made a hell of a bulge under the carpet. That must be 2" across. Never seen one maybe someone in solihull lost a bespoke trim tool 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle |
12th Apr 2010 1:53pm |
u sure about this? |
12th Apr 2010 1:54pm |
