![]() | Home > Puma (Tdci) > Part found under the front carpets - what is it? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
Hi all
While routing the GPS cable under the front passenger seat in the landy, I found this metal part under the carpets. Anyone know what it is/does, and whether I should be worried or not? ![]() Click image to enlarge *edit: added proper pic URL -- Regards, Nakkiran Last edited by Naks on 12th Apr 2010 8:26am. Edited 1 time in total |
I can't see any images..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Oh No
![]() ![]() K Nak ered Original Member Pie n Pea Club. 110 HCPU Tipper |
yaya. ![]() |
Sorry Naks..................
![]() 110 HCPU Tipper |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Can't see the image either
![]() + New Defender 110 First Edition |
how about this one: ![]() Click image to enlarge |
Really looks like a valve seat out of a gate valve, but why that would be in the car I don't know, does it split by levering just under that top rim with a sharp screwdriver Original Member Pie n Pea Club.
110 HCPU Tipper |
Not sure, haven't tried. Most likely explanation is that someone working on the car left it there by mistake. Maybe even from the factory ![]() |
Never seen that before. Why would it be under the carpet? Was it just loose?
Maybe something fell off the production line ![]() + New Defender 110 First Edition |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Clutch release bearing, perhaps?
Intresting if it is as it should be in the bell housing and not under the carpets ![]() Joe NB: the truck would not be going if the release bearing is not in place!! JLS 'El Pepe Flamenco' |
it's a warm air/cold air valve 2.4 90 XS
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 ![]() ![]() ![]() |
Must have made a hell of a bulge under the carpet. That must be 2" across. Never seen one maybe someone in solihull lost a bespoke trim tool
![]() 55 TD5 110 CSW Special Vehicle |
u sure about this? |
