![]() | Home > Puma (Tdci) > 2.4 turbo hose |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
Heard a lot about the turbo hose on the puma, a while back mine was replaced under warranty as it was being damaged by a belt I think? (As they do?)
Will this just keep happening and is there something I should do about it as a precaution/prevention? Don't want to have to replace in the future. Don't even know which one it is but maybe someone has a nice picture with a big red arrow haha! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Replace them with stainless steel pipes.
I wouldn't even know which pipe it is I'm afraid! Can it be explained/pointed to? Cheers, David
Would like to. As some here know very well, ![]() ![]() I have sent a PM here to Entreq (Red Desert) on Dec 29 inquiring about these pipes, but even if I noted that Red Desert posted on here about the new coming version of Entreq 110 splash guards that very same day or the day before, my PM is still in my Outbox, so unread. ![]() I would like to replace these rubber standard turbo hoses by SS as soon as my truck comes out of its extended warranty later this year. Somebody here mentioned once that Bell tuning produce a similar SS turbo pipe set for the Puma 2.4, but all I can find on his site is a silicone pipe set. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 ![]() ![]() ![]() |
I have damage turbo hose in my 2,2 110, the problem is sharp edge in turbo charger.
Best regards BOŠTJAN SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
I've got stainless ones fitted....
![]() ![]() Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
When they were looking at mine today they checked the hoses , the one that goes most rubs on the steering rack
frogface65 Member Since: 25 Dec 2013 Location: kent Posts: 5 ![]() ![]() ![]() |
hi
On 3rd hose , with no answer from the dealer .Had one go rubbing on steering rack and 2 on front pulley . The pipe expands under load ,seems very soft .The dealer has put latest fix on but went again the next day .I will update when they get back . Cabled up out of the way by land rover ass. |
With upgraded modificdations the original ones have also been known to collapse under pressure too. If you go through life with your head in the sand....all people will see is an ar5e!!
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Is there a stockist for hard piping kit? ??? I too am very interested in avoiding pipe issues
In the absence of any forum sponsors coming forward with the offer of stainless pipes you could give Darton Fabrications a call to see if they have anything 'in the pipeline' for later model Defenders.
http://www.dartonfabrications.com/2.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Cheers for that ill investigate the idea later if I free up at any point! Lol
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 610 ![]() ![]() |
Just noticed this post while having a browse.
I'm sure we have the 2.4 hard pipe kits in stock, as pictured above. Give us a call on 01472 812900. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Sorry a bit OT.
I do like the Alive avatar ![]() |
