![]() | Home > Puma (Tdci) > Injectors damage the engine?? |
Interesting the OP two years 8 months and 85,000km after injector change posted....
Is it cylinder 3 that is now holed the same as the original injector failure? Originally the vehicle had stood still for two years...
and then....
Read into this what you will but there seems to be a lot of unusual circumstances? Red-Dot also posted....
Is there something to worry about or not? Hope Caterham doesn't notice this thread..... ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 5th Jan 2014 9:38am. Edited 1 time in total |
Eric L Member Since: 16 Aug 2007 Location: IN93uc Posts: 15 ![]() ![]() ![]() |
A lot of destroyed engines are fitted with Denso injectors
Yes but before this thread I hadn't heard of it? I must have missed the previous one. Are we talking lots of Defender engines or ford engines fitted with Denso injectors?
The two that are documented here with the extenuating circumstances of one of them and the higher mileage of the two doesn't seem like 'lots' to me. What is reassuring is Dgardel's and Red Dot's posts but still doesn't answer my question? Is it or is it noth worth spending time worrying about this issue and can you identify a Denso injector easily? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
There are mine :
Number 3 on right , 4 at left. 3 hard to extract and 4 blocked in the cylinder head extracted with spécifics tools . ![]() Click image to enlarge . Look at the noze of n°3 distorted ! ![]() Click image to enlarge . Denso injectors with the same issue as CRJ : Noise , smoke when cold and finaly run 3 cylinders. Fixed with 4 news injectors Engine seem ok rigth now. For how long ? The engine has not been opened , I don't konw pistons are OK ![]() My Def was manufactured during October 2007. December 2007 110 Defender. 106000 KM |
Interesting, thank you for your replies. Should be able to pop the bonnet and check just to appease my conscience.
![]() Treat every day as if it is your last....one day you will be right!! |
I edited my last post because I got it wrong
think the 2.4 has denso injectors but we do injectors on mercs , Renaults , peugoets , fords, all makes they all get problems just luck of the draw really seen transits come in with filters completely full of dirty water from filling from cans . and you change the filter drain the tank fresh diesel and off they go. cant remember one coming back in while later with problems but they are the kind of people who change vehicles quite often. BUT to avoid engine damage have it looked at when problem running starts not when it wont move anymore! |
sorry if you went and looked because of my post about what different injector look like I got that bit wrong. denso and bosch don't look much different , denso have a bit more rounded top to the solenoid than bosch and return pipe is clipped to top diffirently . bosch have what looks like a r clip in from the side holding return pipe . denso have a flat looking clip. sure 2.4 pumas got denso if you search on ebay for defender injector you can get pic of what they look like Last edited by munch90 on 5th Jan 2014 11:57am. Edited 1 time in total |
Apology not needed I didn't! It's raining and on reflection I don't think I'll bother.....
Good advice though Munch thank you. I think I may be beginning to exibit Caterham like traits. I have a reliable 90 that has given me no real issues mechanically in nearly 6 years of ownership, I do drive it quite hard too. No transmission or clutch issues we hear about so often. I also use Millers on every fill up. Think my worry was a 'momentary wobble.' Will increase my medication and bear in mind your advice and address any issues the moment any symptoms appear. ![]() Treat every day as if it is your last....one day you will be right!! |
