Home > Maintenance & Modifications > Wipac versus RDX (bolt on bits) LED lights.
Page 1 of 3 123>
3 Lions
Australia 2006 Defender 110 Td5 SW Chawton White
Hi,
Am after opinions on Wipac versus RDX Led lights.
Am after Improving my Sidelights and rear stop/Tail lights.
Want to go to Led, but was just wondering if there is much in difference between the above mentioned.
Any Opinions/Thoughts greatly received. Thumbs Up
Col. Very Happy 1979 Series 3 109 FFR (ex Aust Army.)
2006 Defender TD5 110.
2012 Trackabout CT.
Post #295609 4th Jan 2014 4:26am
LR90XS2011
there are other links on here , I have RDX and am happy with them so far but early days DEFENDER 90 TDCI XS,
Post #295611 4th Jan 2014 6:30am
carrotbay
United Kingdom 2008 Defender 110 BMW M57 3.0 Diesel XS CSW Auto Santorini Black
Just put on a set of clear RDX from BoB .. very happy Thumbs Up 2008 Defender 110 XS SW - M57N2 / 6HP28X
Post #295614 4th Jan 2014 8:35am
As mentioned in a previous thread, I'm not keen on Wipac really but RDX seems good.
Not keen on Le Perei either for that matter.
Quality of lights can be extremely good and awful. â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #295651 4th Jan 2014 10:38am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Iv'e had a full set of RDX lamps on mine since mid 2012 .. no issues whatsoever, A vast improvement over standard lamps and I'm very happy with them Cool Guns and Landrovers .... anything else is irrelevant.
Post #295696 4th Jan 2014 2:37pm
Jim_Bean
I have a full set of Wipac LED lights, sides and indicators etc
They are easy to fit just unplug the old and plug in the new. You will have to reverse the wiring for Defenders after 1998 (as i found on my MY13).
Don't use the Wipac relay through. It works fine but you will loose the trailer warning, instead it will flash all the time the indicators are on. If you go for the Wipac LEDs i would advise you then buy the RDX relay as it will retain the trailer warning function.
Post #295701 4th Jan 2014 3:07pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
I've had RDX LEDs and now have Wipac units, not much between them to be honest but I refer the look of the Wipacs. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #295809 4th Jan 2014 8:01pm
K9F
I have just swapped out standard for Wipac clear LEDs. Due to my rear lightguards and the fact they are designed for OEM lights I needed to source some as close to OEM as possible. These were a tighter fit than OEM.
Standard front.
Wipac LED.
Have got the Wipac fog and reverse LEDs on order and am considering doubling them up on the rear instead of just one of each. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420655 2nd May 2015 2:48pm
Venomator
RDX here too...
fitted a full set front and rear from BoB and they are not only easy to fit (even I managed!)... Mr. Green
But they are a vast improvement on the bog standard JLR excuses for lights... Thumbs Up
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #420665 2nd May 2015 3:18pm
gilarion
WIPAC Led's full set fitted a year ago with no issues, would not be surprised if Bolt on Bits RDX lights were in fact WIPAC as well sold under they RDX brand as they look identical.
However which ever set you choose don't fit the WIPAC relay but buy the RDX led relay its expensive but works. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #420666 2nd May 2015 3:21pm
Completly RDX on mine, all good. Thumbs Up
I think you'll find the RDX and Wipac have a different reflector and LED pattern.
Not massively different but there, or do I understand anyway.
Post #420706 2nd May 2015 5:22pm
K9F
The local supplier didn't have any Wipac clear reverse or fogs but he did have some Bearmach ones that were also 'E' marked but I wasn't keen on the lens/led pattern. My OCD wouldn't let me rest unless I stick with the Wipacs as they looked better too.
Have binned the doubling up of the lights as my swing away prevents this so will just replace the OEM ones. Wasn't in the truck when I went to order them but it did seem a reasonable idea at the time. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #420708 2nd May 2015 5:26pm
K9F
A couple of people have mentioned this but I found no issues whasoever with the Wipac relay supplied. No need to shell out a further £30 for the RDX relay. Not sure if the Wipac relay may have been upgraded but it came with the kit and works a treat with the trailer light being adjustable to the point it flashes only once, exactly the same as having OEM lights fitted.
Thumbs Up
Finally collected and fitted the NAS Wipacs. Unfortunately whereas all the remaining Wipac indicators, sidelinghts, stop and tail came with connectors the NAS ones didn't. Decided to use waterproof aerograde jiffy connectors that with the right tool can be disconnected when and if necessary. Even had some blue cable ties to match the jiffys to secure them together and placate my OCD.
Post #423769 15th May 2015 11:30am
Caterham
another option not mentioned and as the saying goes - you pays your monies and takes your choice.
you could consider just going fof the led replacement lamps of course?
site sponsor can sort - AF
Post #423774 15th May 2015 12:03pm
walfy
Anything but BoB. They could give them away for pennies and wrap them in gold leaf, but they won't get a penny of my money. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #423842 15th May 2015 5:24pm
Page 1 of 3 123>
