- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Lorryman100
Not had anything similar but what were the logged DTC's for the MIL lamp? My first impression on your symptoms is the Fuel overflow valve on the fuel pump is faulty allowing air (drop in pressure) into the High pressure side of the pump. but it could be a number of faults ranging from the fuel pump to an issue with the pipe work to the fuel cooler or a leak in the cooler housing or the fuel pump itself. The only way to really tell is do a live data session on SDD and watch to see what the high pressure side of the pumps readings are at the common rail. An easier option would be for the dealers to swap out a known working fuel pump into yours to see if the pump is at fault.
3rd Jan 2014 2:37pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
