Home > Technical > New puma leak help
110SEB
New puma leak help
What's this that's dripping oil? It sits above the linkages in the track rods (i think) - is it the PAS pump? You can just see it in these photos. It's the large object in the centre of the pic. The oil is just coming out of the bottom of it. No MIL light yet.
All help in identifying what this is, appreciated Thumbs Up
Post #29518 11th Apr 2010 6:20pm
MK
The PAS pump should have some oil/dirt behind the pulley. Uses the same oil from the engine, so thin.
If not, could be the front main cranckase seal. Puma 110" SW
Post #29521 11th Apr 2010 6:38pm
110SEB
In fact in those pics i had just wiped the area. Quickly enough there's a drip of oil on the end.
Ringing LR Assist from work tomorrow. Yet another f****** problem with the truck. We're seriously thinking about chopping it in for something non-LR.
Post #29525 11th Apr 2010 7:28pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I don't think it's the PAS pump - that's way off on the near side of the engine bay - near the top. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #29557 12th Apr 2010 5:19am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Shocked Oh dear it's the steering box isn't it, the one with the arm coming off it, they often leak on older models but will eventually need a seal kit or replacing Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #29560 12th Apr 2010 7:17am
roel
To me it looks like the steering housing and not the pump.
The bottum seal leaks more often but I didn't expect it with a Puma yet. Roel
2003 90 Td5 (2009-now)
Post #29561 12th Apr 2010 7:18am
110SEB
Yup it's the steering box that's gone. Back into the dealers for the second time in a month with a part that isn't fit for purpose breaking.
Who was it that said to own a Puma out of warranty requires either stupidity, blind faith or enormous wealth? All three I'd say.
Rolling Eyes
Post #29577 12th Apr 2010 10:44am
roel
The good thing of a defender is that a lot off things you can do yourselves.
A steering box isn't cheap but you could easily save the manhours charge and probably you could get a steering box cheaper elswhere than what the dealer is charging you.
I am not an automotive engineer but I do 90% off al work on my LR's myselves. Roel
Post #29590 12th Apr 2010 12:33pm
