Home > Maintenance & Modifications > Removal of bulk head under front seats
pepekleinhans
South Africa
Has anybody remove the bulk head under the front seats of a 110 before. I am planning to move my batteries to the back and fuse box also to the back seats, and remove the front bulk head. close the floor up level with the rest of the car. Make frames for the seat and install again, like a normal car. this will give loads of extra leg room and now you can make storage space under the front seats.
As anybody done this before. I hate that bulkhead as it restricts leg room in the back a lot.
is there any reason why I cannot do it, or why nobody has thought about this before.
Just an idea I have and are busy looking into it. it does not seems to be such a big issue, all I need to is to make a extension for the wiring loom and the batteries should be easy deal, I hope.
Pepe 2005 Discovery 3 HSE
2007 2.4 Puma Defender
1976 series 3 with Ford V6 engine
Post #294802 1st Jan 2014 9:41am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
The only series/defender i have seen without a seat box was the Tempo version of the series one that was built under licence in west germany.
It had a flat floor to allow troops to access the rear seats through the front doors as i believe it did not have a drop down tailgate.
Would be most interested to see how you get on with it. 2005 Td5 90 XS
Steve
Post #294806 1st Jan 2014 10:12am
Mountain_man
Wales
I did something similar to this. Not sure if I have a build thread on here though. Will check out some pics for you
Post #294834 1st Jan 2014 12:07pm
Mountain_man
Wales
A couple of pics
With carpets
Shortened and highly modified seat box.. (You still need the raised central bit to cover the handbrake and back of transfer box so a fully flat floor is not an option)
Some of the additional floor framework I had to build in to support the new flat floor (Ignore the bits in the foreground, they are for the 2nd fuel tank and the battery box in the rear wheel arch voids.
Flat floor in place
Made with enough room for a 25 litre water container
Post #294837 1st Jan 2014 12:12pm
pepekleinhans
South Africa
Mountain Man
Thanks for the details, that looks good, with the handbrake I am looking at a hydraulic system, not a LR design one but myne, and then with the transfercase issue, I geuss I will look at it when I get there. But what you done, looks very very good, and that is excatly what I am looking at.
Once I am done I will post some pictures, but I will propable not start before April. and the moment it is still in the idea phase of my nind.
Post #295041 2nd Jan 2014 6:48am
Cheshire110
Just another option to think about in case it's helpful or anything?
If your just looking for storage space, maybe you could move the battery, weld up the top of the seat box (the 'lid') and then fit a larger folding 'door' on the front end. You wouldn't have to remove seat to access storage then as you do normally and you'd get bigger opening etc.
Otherwise you have a good thing to work on from Mountain man but just something that popped into my head! Would require much less modification. Cheers, David
Post #295064 2nd Jan 2014 9:44am
