![]() | Home > Maintenance & Modifications > Removal of bulk head under front seats |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
The only series/defender i have seen without a seat box was the Tempo version of the series one that was built under licence in west germany.
It had a flat floor to allow troops to access the rear seats through the front doors as i believe it did not have a drop down tailgate. Would be most interested to see how you get on with it. 2005 Td5 90 XS Steve |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 ![]() ![]() |
I did something similar to this. Not sure if I have a build thread on here though. Will check out some pics for you
A couple of pics
With carpets ![]() Click image to enlarge Shortened and highly modified seat box.. (You still need the raised central bit to cover the handbrake and back of transfer box so a fully flat floor is not an option) ![]() Click image to enlarge Some of the additional floor framework I had to build in to support the new flat floor (Ignore the bits in the foreground, they are for the 2nd fuel tank and the battery box in the rear wheel arch voids. ![]() Click image to enlarge Flat floor in place ![]() Click image to enlarge Made with enough room for a 25 litre water container ![]() Click image to enlarge |
pepekleinhans Member Since: 12 Jan 2013 Location: Cape Town Posts: 25 ![]() ![]() |
Mountain Man
Thanks for the details, that looks good, with the handbrake I am looking at a hydraulic system, not a LR design one but myne, and then with the transfercase issue, I geuss I will look at it when I get there. But what you done, looks very very good, and that is excatly what I am looking at. Once I am done I will post some pictures, but I will propable not start before April. and the moment it is still in the idea phase of my nind. Cheers Pepe 2005 Discovery 3 HSE 2007 2.4 Puma Defender 1976 series 3 with Ford V6 engine |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Just another option to think about in case it's helpful or anything?
If your just looking for storage space, maybe you could move the battery, weld up the top of the seat box (the 'lid') and then fit a larger folding 'door' on the front end. You wouldn't have to remove seat to access storage then as you do normally and you'd get bigger opening etc. Otherwise you have a good thing to work on from Mountain man but just something that popped into my head! Would require much less modification. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
