Home > Maintenance & Modifications > Fitting a check temp sensor
Page 3 of 4 <1234>
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Go Beyond wrote:
Can you post up the wiring details for linking into the aircon please
Cut into wire number 4 (black and grey) and connect the blue wire from the check temp to one end of it and the grey wire from the check temp to the other side. Very easy to do and works very well. Climate control for £50! Very Happy
Post #235063 12th May 2013 9:56pm
dgardel
Italy
the relay of the CheckTemp must be connected to the pin 4 of the C0275 Defender connector (Aircon ON/OFF)
CheckTemp installation scheme
LR scheme
LR connector library
In this way you turn-ON the A/C and the CheckTemp A/C function: now the CheckTemp will manage the internal Temperature like you request (Check temp stored value)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #235078 12th May 2013 11:30pm
Thanks guys Bow down
This is pretty much the last connection I need to make on the FCX 130 dash and identified the switch circuit on the A/C switch but couldn't put my hands on the Checktemp instructions Embarassed
Post #235087 13th May 2013 5:35am
dgardel
Italy
No problem my friend
https://www.defender2.net/gallery/albums/u..._fr_es.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #235091 13th May 2013 6:38am
Excellent !
Thank you dgardel Bow down
Post #235094 13th May 2013 6:43am
muddypaws
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Well, another successful installation of this excellent product, (bought off Amazon)
A massive thank you to all those useful posts before without which I may not have attempted it.
Just a few additions to make it even easier for any doubters!!
1) It is quite a 'manly pull' to remove the fascia -I didn't need to unplug the clock
2) If siting the display high to the side of the steering wheel, put masking tape on the wheel itself as it is easy to catch it with the file.
3) The plastic dash is sl too thick for the retaining clips of the display surround so file diagonally to thin them and it sites beautifully
4) If you remove the plastic moulding just above the steering wheel, you can just see the large oval grommet taking the main loom to the engine bay. A knitting needle pushed through from the engine bay can then be used to draw the outside sensor wire back through into the engine bay. It is a double grommet so be patient and expect to feel it go through a second resistance!
5) Tape sensor wire to loom on wing and I dropped it down behind the radiator grill which I removed to site the sensor itself.
6) Inner sensor easy to locate on dash at bottom right as shown previously
Job done -about 1 hour for electrics, 1 hour for filing and 1.5 hours for the outer sensor (but I did stop for 2 cuppas in that time too
All I need to do now is work out the German instructions to set the clock!!
Thanks again to those before me!! Richard
Defender 90 SVX
Post #282728 16th Nov 2013 5:50pm
martinfiattech
Well theres another thing to add to the list of ideas, I`am gonna be doing over time just to pay for the extras, well less caviar for tea !!!
Post #294299 30th Dec 2013 6:55pm
muddypaws
Not a stupid price -£65 from Amazon if I recall
Ah just seen -another Leicestershire fellow!! Richard
Defender 90 SVX
Post #294429 30th Dec 2013 10:55pm
martinfiattech
Well if I see dodging in and out of the new bus lanes on lutterworth road I`ll wave. And if your not from Leicester heres how to waste 3 million quid to save 3mins from one part of town to another..
Post #294576 31st Dec 2013 2:57pm
Xelr8
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Old thread I know
But assuming alls ok wi mi motor then I think I'll be another for this Mod Cool
Post #388504 14th Jan 2015 7:38pm
muddypaws
Yes - all is fine
Only sl mod would be not to site the internal sensor as close to the heater but would route to another location Richard
Defender 90 SVX
Post #388684 15th Jan 2015 11:23am
Jamie W
United Kingdom 2009 Defender 90 Puma 2.4 HT Galway Green
fitted checktemp
Just fitted one of these units, I wanted one for a while but just could not bring myself to cut the dash to fit it. Eventually I gave in and purchased one.
Thanks to all those who posted their comments and fitting instructions- this made the whole thing very painless indeed!!!
purchased from amazon at a reasonable price for what is a good quality and accurate bit of kit- looks factory fit!
Post #402238 25th Feb 2015 9:58pm
Furball
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
This is very helpful thread, thanks to contributors. JB. Very Happy
Post #498683 31st Jan 2016 4:40pm
Furball
Re: fitted checktemp
Jamie, please could you share the amazon link. I want to order one of these and can't find it on amazon. Thanks, JB
Post #498687 31st Jan 2016 4:44pm
muddypaws
Difficult to find on amazon but this is the chappie Thumbs Up
http://www.amazon.co.uk/in-pro-10330-in-pr...pro.+10330 Richard
Defender 90 SVX
Post #498942 1st Feb 2016 7:38am
Page 3 of 4 <1234>
