![]() | Home > Puma (Tdci) > Best trailer for a Puma |
Ifor all the way
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Dude - that's some pretty low profile rubber you have on that trailer
![]() + New Defender 110 First Edition |
mhill Member Since: 24 Jan 2010 Location: Tendring, Essex Posts: 46 ![]() ![]() ![]() |
More like 95psi
I think you could be right i put 65 psi in and that is plenty with what i carry and i carry lots of concrete
I guess it will work but can realy tell the diference when you have 3ton up your arse with saggy under inflated rubber, both the Ifors I've had there where little stickers above the wheel arch. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
Ive dragged ifors - upto their 1ft car transporters over muddy rutted fields to get cars - not too rutted mind but they always get there! Mike |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I've pulled that ifor over very rough fields and through some pretty boggy mud and it just copes. I've never really tested it though. The Sankey on the other hand will go wherever the 110 will.
The conclusion here in my opinion is... horses for courses ![]() |
What's a Sankey like being towed at 70mph plus on a motor way though? |
Fine once Uncle Ray's extended the draw bar
![]() 110 HCPU Tipper |
Fine surprisingly. With a rag top on it is a pleasure to tow. However, isn't the towing speed limit 60mph? I may be wrong!
