Home > Td5 > Snorkel issues
Page 2 of 2 <12
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
Cheers landy Andy I'm sure it's doable but for peace of mind ill run a single pipe with no joins to leak
Post #293310 26th Dec 2013 9:35pm
Hock
England 2014 Defender 110 Puma 2.2 XS CSW Java Black
does anyone know if the mantec plastic jobbie is a sealed unit with pipe etc, or would that be a raised air intake with leaks lol?
Was looking at getting one of these in jan:
http://www.flatdoguk.com/defender---plasti...nd-td5~161
Post #293700 28th Dec 2013 5:29pm
Anderzander
The only one I've seen that seals with a pipe is the Mantec 300tdi model - which used to be the same part as listed for the td5, but for some reason was replaced in their line up by one that sealed against the wing.
Post #293709 28th Dec 2013 6:18pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
The plastic jobby, Hock is sadly merely an intake. I tried to fit it to my old Double Cab, and never managed to seal it. Doubt apaloosadude managed it either.
Snorkel is best bet for reliability, but even some of their new ones don't have protruding pipe section... I expect finding the correct Mantec one is also an option as mentioned. 1998 110 300Tdi White Hard Top
Post #293725 28th Dec 2013 7:01pm
sandylands
I did what millsey94 said and ran a pipe from the air box then up inside my snorkel-the only way i felt confident after almost drowning a 200tdi. I found this method worked perfectly 100percent water proof- although a did have a bag from the road get stuck on my snorkel and cause then engine to die on me towing on the a35!!
Post #293934 29th Dec 2013 4:32pm
Page 2 of 2 <12
