![]() | Home > Maintenance & Modifications > Cruise Control Wiring |
either Radio Spares (RS components) or talk to Tim at the MobileCentre.co.uk
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 ![]() ![]() ![]() |
What kit did you go for Tim? William
look here
http://www.defender2.net/forum/post224575.html#224575 Normally, I do not like to "cut" the original harness/wiring...... So for the installation of the cruise control it is necessary 3 "Y" connections 1. the throttle (provided by the kit seller) 2. The clutch switch (normally the installation need to "current steals" (that I hate, I do not know the correct translation) 3. The brake switch C0029L (the right switch, not the left), same as point 2. So I create my own "Y" The brake one isn't easy, I bought the female (Motorcraft) from USA and I create the male one sacrificing a new brake switch ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge everything flooded with hot glue ![]() Click image to enlarge and the clutch "Y" (commercial connectors) ![]() Click image to enlarge ![]() Click image to enlarge and the right stalk..... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 ![]() ![]() |
I like your work. I also do not like to cut the factory loom.
Where did you get the picture showing the connector locations? Thanks, Mark |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 ![]() ![]() |
It's a mobile centre unit... I'm looking at making a small kit for people so they don't have to cut up their original loom... that way if you have any issues. The kit will be easily bypassed in case there is a fault...
If people are interested please pm me... The only issues are the connector for the brake switch and the rpm pick up from the dash loom...... Something like Delgardo has done would be the way forward.. If I make a kit it will consist of 1, Main loom T-Piece (which will fit between the ign barrel and loom) 2, Clutch Switch T-Piece 3, Brake Switch T-Piece I would probably make it to full military spec, So DR25 with potted connectors and heat shrink boots It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Zanshain Member Since: 24 Dec 2013 Location: Munich Posts: 3 ![]() ![]() |
Hi folks,
does anybody offer the wiring kit described above? Looks really perfectly built, I am just wondering how the connection to the combination meter was done? Hope we are talking about the same cruise control, that I am about to buy: http://dl.nakatanenga.de/anleitung/tempdeftd4.pdf Regards Stefan |
