Home > Td5 > if you use lift hand indicate all light flash too
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
HI bit of a problem if you use lift hand indicator all light flash too Sad Question Question
any ideas
i have also noted that if light are on left hand indicator as well, con checked with meter and 0.1ohms between wire green/red and red/black with lamp out Question i am going good look in the day light tomorrow at trailer socket wiring as all exterior lighting meat at this point Exclamation
Post #292175 21st Dec 2013 1:49pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
What...???
cheers
simon
Post #292178 21st Dec 2013 1:58pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
If all your lights are flashing when you indicate to the left, it sounds like you have a bad earth problem.
Check the connections to the indicators would be the first thing.
Post #292180 21st Dec 2013 2:14pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Damp and muck can get into the lamp holders/connections quite easily and cause that 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #292214 21st Dec 2013 4:08pm
dorstsmith2
if you pull on wiring loom right hand side back end the problem can be made appear and disappear now to find out how fix it Question Sad
New chases loom Crying or Very sad
Post #292395 22nd Dec 2013 12:03pm
deep down
It sounds like you've got a bad connection in that area somewhere.
Check all the connectors in that area, disconnect them, clean them with something like WD40 or contact cleaner and make them back up.
If this doesn't cure it, move each wire at the plug connections until you find the one thats causing the problem.
It will be something simple.
Post #292605 23rd Dec 2013 7:02am
dorstsmith2
thanks deep down have find the problem need to find away to get the loom out
Post #292609 23rd Dec 2013 7:22am
mk1collector
Try disconnecting the tow socket from the loom underneath the right hand rear wheel arch (there's a plug behind a plastic panel in the rear wheel well) and spray contact cleaner in the loom plug. Check to see if the lights all work before re-connecting the tow socket.
Post #292639 23rd Dec 2013 9:59am
