![]() | Home > Technical > central locking - grrrhh ! |
rs2315 Member Since: 16 Sep 2012 Location: yorkshire Posts: 125 ![]() |
Hope my guy's can sort mine. Oh how I loved those days of just pushing the latch down and just shutting the door. Technology ![]() rs2315. |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
I thought they were going to plug a new bit of loom in but I gather a crimp and some heat shrink has sorted it ?
I still think the door needs moving back a little but hay ho. |
Removed the rubber boot, and as somebody has all ready mentioned such skinny wires ![]() Just stupid using wires like that, and hoping rubber case will protect at crease point. ![]() I pulled on pink wire, and guess what, it's no longer attached to the other bit of pink wire. Well at least I've sussed why central locking not working, now for a fix. ![]() rs2315. |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
My 110 has just come back from a MOT. While locking the vehicle for overnight storage the mechanic from the garage found the rear offside door would not lock and that the reason was a broken wire, new short length inserted with soldered ends and it cost less than a pint of beer.
![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
Well if I can fix it I'll treat myself to a pint
![]() At least if the other doors give up the ghost, I'll know where to start looking. I thought it was just the Italians that couldn't do wires ![]() rs2315. |
Just a final update, central locking working again
![]() Took the job on myself. Removed rear N/S door card thinking it would give me a chance to pull rubber cover along, so i could get to wires more easily. Waste of time, no better off, luckily I didn't break any door card plugs, so was able to put it back on no probs. Pondered for a while, then decided to snip down the seam of the rubber cover, cutting just enough to get to broken wire. Used 15 amp butt connector, and crimped nice and tight. The other wires outer cover had split, but had not gone right through, so taped it up good and proper. Pushed all wires back in to rubber cover, then taped up the split I'd made. Can't really tell theres any tape, so job looks good. If I have any more probs down there at least I'll have easy access to wires. rs2315. |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
Just what I was looking for as my o/s rear door has just stopped locking. 1 month out of warranty.
![]() AlanH. |
Done it. Checked the wire and sure enough the pink one had broken. So I soldered a short length of slightly bigger wire and covered it with heat shrink and bingo! it works OK.
Thnx for the advices. AlanH. |
Well done Mr H.
So not such a great fix....broke again
![]() And so has the brakes on the caravan so suspect the trailer wiring outlet at fault again (loose wiring again?) |
Bloody hell mate - how many things have gone wrong now
![]() It's a bit beyond a "Monday morning" motor now, don't you think? That being said, the wires just broke inside my offside passenger door - alarm kept going off when my daughter opened it before I noticed ![]() Next time I'll drag the wires out and solder something sensible in their place... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Oscar Romeo Member Since: 16 Apr 2014 Location: South Yorks, the pinnacle of all human achievement Posts: 121 ![]() ![]() ![]() |
this fault is common on a lot of vehicles. the copper can break inside the cable leaving the insulation intact making very hard to spot. this kind of fault is usually intermitant to add to your woes.
That a side, one thing not mentioned on this thread is that thin cable will be probaly be "thin wall" this is now widley used by vehicle manfactures. the premise being apart from the obvious cost saving of using less copper, the insulation being thinner the heat is disapated better causing less vehicle fires. also the restivity of the circuit changes and extra load can be added if larger cables are fitted instead this in turn can pull down voltage on canbus systems and cause all kinds of problems. my advice would be always replace like for like, i know this theory dosent always work but its often the safest way of doing things. |
thanks for that info.
this time its just stopped work it may have shown signs of being intermittent once or twice but no seems to have completely given up. not for this reason because as you say this connection to the door is a common problem however I do have serious concerns about the wiring loom. - can I ask has anyone had, is anyone aware of the purple / black wire in the rear wheel with connector (12v aux that appears to be spare) to have fallen off twice due to the copper in the cable corroding. mine fell off within a few months. new one crimped on by dealer and again cable corroded and it fell off !! ?? and as above now on second trailer wiring and got an issue with brake light (and no its not corroded in the plug - looks new) ? just concerned when I read threads about brake lights / engine running problems? hmm |
