Home > Puma (Tdci) > Puma does not start in cold weather |
Mine, at -15°C start well with only 1 time plug.....
Also past year at -26°C (after 30 mins with Webasto ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
17th Dec 2013 11:47am |
hi Khasar, the pipe that runs from the back of the airbox to the rocker cover, about 150mm from the airbox there is a connection, are there any electrical wires on the pipe ?
17th Dec 2013 4:30pm |
vodonos Member Since: 13 Jan 2013 Location: CERKNICA LAKE Posts: 29 |
I have similar problems with my Puma 2007. When temperature dropped lower than -12C, I had gas burner with me. When I can feel missing fuel I had to heat up the filter with gas burner. I never had these problems with 2001 TD5, they are both in the same open garage and have the same fuel. BOTJAN
SLOVENIA Cerknica lake 90 td5 2000 110 2,2 2012 |
18th Dec 2013 10:24am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Hi there
Good to know that. I will be in similar temps during this summer and I dont like to be stick somewhere. BTW, check this bulletin http://www.defender2.net/forum/topic1076.html Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
18th Dec 2013 11:44am |
Khasar Member Since: 09 Nov 2013 Location: Ulaanbaatar, Mongolia Posts: 8 |
vodonos: lot of people still do that here, especially on russian cars. some just make campfire style fire under the
engine, but doing that every morning at temperatures of -20 to -30 is not for me. there are limits to even a defender owner but yes i've seen lot of people perform similar measures which do get car started. But would advise to check the glow plugs on yours, might be a similar case with mine where some are not working. although it will take you 30 min to 1 hour to get them, well worth the time and knowing if its case. Eduardo: Good luck on your trip and thanks for the bulletin info. Click image to enlarge |
18th Dec 2013 4:46pm |
