Home > Maintenance & Modifications > Battery cut out switch |
Ian Mac Member Since: 16 Oct 2013 Location: Essex Posts: 53 |
I was thinking of doing the exact same thing and my plan was just to break the starter motor supply or fuel punp supply (like the immobiliser) but it all helps
Ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
17th Dec 2013 3:41pm |
Yes, run a permanent bypass around the switch that incorporates a small fuse. That way, if somebody tries to start it without the key switch sctivated the fuse just blows rather than having anything melt. Darren
17th Dec 2013 3:43pm |
i like that idea..... i might try that one
Thanks ian 2008 TDCI 110 XS 1985 90 300tdi. Gone 2005 RR vogue TD6. Gone |
17th Dec 2013 3:46pm |
Diablo Member Since: 26 Oct 2011 Location: Basingstoke Posts: 335 |
a resistor is better - get the right size so that enough, but not too much current can flow. something like this (random one, so spec is almost certainly wrong: http://www.maplin.co.uk/p/wirewound-3-watt-22-ohm-resistor-w22r)
This sort of resistor will turn excess current into heat, rather than blowing, like a fuse. Whilst you could get a resetable fuse, it will be harder to locate it for access to reset. |
17th Dec 2013 4:53pm |
Marky Boy Member Since: 25 Oct 2013 Location: Maidenhead Posts: 96 |
Thanks for that the by pass idea sounds good, I guess a 1 or 2 amp fuse would be fine as the alarm and clock current draw is minimal.
17th Dec 2013 4:56pm |
i would say bigger as the central locking does the hazards lights too.... 10-15a??
17th Dec 2013 5:00pm |
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 |
Just so you know putting a switch on the fuel pump doesn't work as a 100% cut
Just limits performance, you just lose the top 30% of the engine rev range so your top speed drops to maybe 55. Engine just sucks it through Defender 90 XS TD5 (03 Reg) |
17th Dec 2013 5:02pm |
The trouble with the fuse is that if/when you forget about the cut off switch, and turn the key, the fuse will blow. Then you've got to muck about replacing it
17th Dec 2013 5:10pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
We supply a 100amp FIA battery cut out switch (nothing special there) but housed in our own design of box that enables the cut out to be recessed into the seatbox thus avoiding passengers from inadvertantly treading on it.
If you cut the carpet / seat box matting to act as a flap its pretty well hidden too. If you already have the cutout switch we sell the housing on it's own http://www.farrowsclassics.co.uk/fcx-BATTERY-KILL-BOX.html |
17th Dec 2013 5:35pm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Also....
If you don't have a battery backed up alarm... Blowing a fuse would kill the alarm |
17th Dec 2013 5:36pm |
Yes, but you're already inside failing to start it at that point
Only once Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
17th Dec 2013 6:12pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
May be fit one of these ........
http://www.ebay.co.uk/itm/30A-AMP-DC-Car-A...1055746139 http://www.ebay.co.uk/itm/20A-AMP-DC-Car-A...1055746255 At least if you do forget you just reset It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
17th Dec 2013 6:18pm |
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 |
Found this while fault find a relay in fuse panel, there is a yellow relay in td5 far left in centre interior fuse box and 300tdi's which if removed immobilises the starter and fuel pump, if a single pole switch was spliced into the relay coil side then you would have a immobiliser circuit which still gives you 12v supply to clocks and radio. Normally in dodgy areas I remove relay as it would deter a thief but will only slow down someone in the know
17th Dec 2013 10:54pm |
Cheers Greg,
Going for the multi layered approach might be the way - stick a switch in the relay coil feed for day to day use and then use a cut out switch with bypass for longer periods. Seeing the FCX switch is what got me thinking about this in the first place as I like the idea of hiding it under the carpet. Thanks for all your responses. |
18th Dec 2013 3:02pm |
