Home > Maintenance & Modifications > Removeable & cleanable noise muffling |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Dynamite is good, however not exactly remove able.
17th Dec 2013 9:47am |
Excuse the typo it's called dynamat! Don't know where that came from I have n,t been on the grog yet!
17th Dec 2013 9:50am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
I use 1.5 mm sheet rubber and foil camping mat but didn't stick it down (outa lazyness),why do you want to clean it underneath,if its stuck down it's not gonna get dirty?? Pov.spec,ftw. 2006, 110,TD5.
17th Dec 2013 11:34am |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
I want a vehicle that can be hosed out & if necessary disinfected (being careful of sensitive areas naturally). So removeable everything, including sound proofing. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
17th Dec 2013 11:40pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
Some parts of the Noise killer kits are removable.
Front Floors (NoiseKiller Sound Barrier) Under Seats (NoiseKiller Sound Barrier) Rear Floor/Load Space (NoiseKiller Sound Barrier) You could try fitting the adhesive parts in reverse so they stick to the carpet instead of the bodywork; for example the part designed to fit the nearside wheel arch would fit to the carpet on the offside. That way the sound proofing will come out with the carpets. Some pictures of the rear tub kit halfway down this page: http://defender90xs.blogspot.co.uk/2013/06...r-tub.html http://defender90xs.blogspot.co.uk/ |
18th Dec 2013 6:40am |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 |
I've got a mixture of Noisekiller and Dynamat (flexible metal sheet with strong adhesive backing) but the NK pads mean the rubber cab floor matting doesn't sit very well after installing.
Dynamat is much better and it is so sticky Im pretty sure you could still hose it out. Search a few photos on here to see what I mean. Ive probably got a little Dynamat offcut if you wanted me to post it to you to try it.. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
18th Dec 2013 8:09am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5690 |
Don't go near noise killer kit if you want hose out. Holds so much water that it's permantly wet. Dynamat for me.
Andy |
18th Dec 2013 8:58am |
