Home > Puma (Tdci) > Puma 5 Seater - want to add the two rear folding seats |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
it might be that simple, it might not it depends on the shape of the rear tub,
if you scroll down on page 16 of this thread by mcma http://www.defender2.net/forum/topic15681-225.html you see he actually cuts the rear arches to make the seats fit, ive bought some puma rear seats and planning to do the same thing in the new year |
16th Dec 2013 12:23am |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 |
That looks like a lot of work! Are you sure that is the same for a 110 ? I havn't lifted the boot carpet and looked for bolt holes yet... I assume that is what I am looking for?
16th Dec 2013 1:28am |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 615 |
You are basically looking to see if you wheel arches are just square or whether they already have the extra step in them as per the photos in the other thread.
If you don't have the extra step then you have 2 options, first you can cut the arches and fit genuine land rover seats or you could look at the Exmor Trim lock and fold seats which fit standard arches. |
16th Dec 2013 7:03am |
Mcma's conversion was from a van with flat-topped rear wheel arches, whereas your station wagon should already have the recessed arches designed to accomodate the newer forward facing seats. The only issue should be whether yours has the various bolt holes and brackets fitted for the seats to mount on to. I'd suggest taking a look underneath and under the carpet to see what's there. Darren
16th Dec 2013 7:04am |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
it is easy for tdci 110SW.
Bolts that need to screw seats are ''stuck'' underneath the floor. (it is easy to see them) so you first carefully drill the floor underneath the floor with a smaller ''nose'' and then drill with bigger drill over the floor so you won't hurt inside of bolt. for seat belts you have to cut the interior. good luck www.newfoundland.gr |
16th Dec 2013 7:37am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
110's are quite easy...
Unlike a 90 a 110 has the correct floor shape - and also has all of the captive mounts in place. However, you need to drill the floor to get to them. The mounting plate is wheel side of the wheel arch. This is easily done with a M8 drill guide. You need the seats and all the fittings, the correct carpets (or cut to suit) and then seat belts and mounts. The grey trims can be easily cut for the seatbelt. I have done a couple of Utility to CSW conversions... Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
16th Dec 2013 7:39am |
