Home > Puma (Tdci) > Max engine revs - hill descent - how high is too high?
Ayahuasca
2007 Defender 110 Puma 2.4 SW Bonatti Grey
Obviously there is no red line on the rev-counter, but I keep it under 3k revs under normal conditions and this works fine.
EXCEPT - going down very steep hills -under engine braking - in low 1st - the sort of hills where you can't let it run away - the revs climb way above 4-5k (can';t remember exactly, but may be even higher). Is this a problem? What do you do - let the engine scream in pain, or feather the brakes to reduce revs, and risk inducing a slide? Changing to a higher gear is of course not an option!
Cheers!
Post #289991 12th Dec 2013 10:43pm
RobKeay
Would not want to do it everyday but it will be fine. Land Rover test their engines off road and they push them pretty hard. Your engine won't blow up and will blow the cobwebs out.
Post #289992 12th Dec 2013 10:49pm
RobKeay
Don't break going down hill off road. Best thing todo is remove foot away from brake pedal to stop temptation of trying to brake There's a video on you tube were a 90 applies the brakes on a steep decent and he tips over.
Post #289994 12th Dec 2013 10:51pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
puma 2.2
Hello,
I can,t answer but on the same subject I have the feelingthat the engine brake is less powerfull as with older land rover.
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #290005 13th Dec 2013 3:54am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Just make sure your engine is at temperature before doing the rough stuff.
And have it run iddle or drive carefully after for a minute or two, so your turbo gets cooled bedore turning the engine off.
In fact, do that always, also after a long drive.
Post #290008 13th Dec 2013 6:07am
Naks
@op On those very log, very steep descents, I feather the brakes very lightly every now and then just to keep the revs down a bit.
It is interesting to note that under compression, the engine is actually not burning any fuel. In fact, after these long descents, the EGT on my Puma has down to as low as 60C!
And yes, let the vehicle idle for a few minutes always! Thumbs Up --
Post #290009 13th Dec 2013 6:25am
Cheshire110
Yes the engine braking isn't great on the puma, I guess the compression is just too big/small (can't remember which haha!) I've found some light braking just to keep the revs down can help, but it usally would cope on it's own- I just chicken out
I got taken around a purpose built quarry at LRE peckforton castle in a 2.2 110 and the driver never once touched the brake, and we were going down slopes so steep that the tow bar bottomed out leaving it.. Coped fine Cheers, David
Post #290026 13th Dec 2013 8:55am
ericvv
Engine braking is quite good on a Puma 2.4. That engine's compression is 17.5 : 1
Thę Puma 2.2 has a lower compression rate of 15.5 : 1
I have tested a friend's new Puma 2.2, and there definitely is less engine braking than on my Puma 2.4
If you do a search, this discussion has come up in various threads already, not everybody agrees with what I say here, but I have experienced the difference.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #290069 13th Dec 2013 11:18am
x-isle
Agree with engine braking on the 2.4, very good.
I suspect even the 2.2 is still better than the Jap stuff. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #290073 13th Dec 2013 11:32am
