Home > Maintenance & Modifications > Carpet/matting on top of chequer plate?
a13x
Any recommendation for carpet/rubber mat to put on top of a storage drawer like the MSS drawer or similar?
Also what do you use as tie down points now the existing points are covered by the drawer?
Thanks in advance
Post #290053 13th Dec 2013 11:43am
walfy
I was going to use plain automotive carpet, stuck down with a very thin layer of a mastic. That way it fit gets ripped/damaged it is easily removed.
I've yet to pluck up courage to drill more holes in the back to bolt it down. Plus I can't make my mind up if I want it up against the cargo barrier or up against the door. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #290055 13th Dec 2013 11:47am
leeds
Loose laid carpet on top of the anti slip/grip mat which woodworkers etc use.
We have original carpet laid on top. A bit of weight in top and it does not move around much.
Tie down points? Consider either cargo tracks in long lengths (£14/m with rings at £7/pair) or in short lengths just big enough for a load ring (£14/2). Alternative is medium weight lash down rings use a large washer behind (£9/6)
Brendan
Post #290060 13th Dec 2013 11:57am
jimbob7
Rubber matting is cheap, easy to clean and will help keep the noise down.
http://www.frost.co.uk/rubber-matting-per-metre.html Pov.spec,ftw. 2006, 110,TD5.
Post #290066 13th Dec 2013 12:13pm
