Home > In Car Electronics > Switches? |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
a One is Earth/GND
b One is Power (connected to a 12v fused power line) c One is the Switched out. When off b & c are not connected When on b & c are connected and b & a are connected lighting your LED in the switch |
28th Nov 2013 11:22pm |
No 1.....power source
No 2.....accessory/item controlled by switch No 3.....earth, enables the led or whatever telltale to illuminate when the switch is in the on position. Often it's up to the installer to find the correct combination which works |
28th Nov 2013 11:23pm |
Johnnyb0 Member Since: 26 Jun 2013 Location: Ulster Posts: 45 |
Thanks Tiger. It's obvious when you think of it. Well, obvious when someone tells you how it works....lol cheers Johnny.
11th Dec 2013 11:42pm |
