Home > In Car Electronics > Switches?
Johnnyb0
Switches?
Hello all, can anyone please explain to me why a switch has three terminals? Saw one on flea bay, then noticed that it had three terminals? I'm a total novice at automotive electronics. Oh, the switch has an LED warning light ob board BTW. Thanks. Johnny.
Post #286157 28th Nov 2013 11:12pm
Tiger
a One is Earth/GND
b One is Power (connected to a 12v fused power line)
c One is the Switched out.
When off b & c are not connected
When on b & c are connected and b & a are connected lighting your LED in the switch
Post #286160 28th Nov 2013 11:22pm
JWL
No 1.....power source
No 2.....accessory/item controlled by switch
No 3.....earth, enables the led or whatever telltale to illuminate when the switch is in the on position.
Often it's up to the installer to find the correct combination which works Whistle
Post #286161 28th Nov 2013 11:23pm
Johnnyb0
Thanks Tiger. It's obvious when you think of it. Well, obvious when someone tells you how it works....lol Rolling with laughter cheers Johnny.
Post #289689 11th Dec 2013 11:42pm
