Home > Technical > Transmission/Gearbox Rattle |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 |
Update from the dealer is that the handbrake was binding, they reckon it is sorted now and the noises have stopped. Getting the paint defects done tomorrow so should have it back Friday.
Just hope they have sorted it. Andy |
23rd Jul 2008 4:11pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
Lucky you - was it easy to get them to resolve your paint defects? its not been that easy for me! Mike |
23rd Jul 2008 4:17pm |
The dealership (Farnell Guiseley) have been fantastic, really supportive and no quibbles over these issues. Have said that if I am not 100% satisfied with the rectification the car will be exchanged. Dealer principle got involved and has rung me regularly with updates.
Top marks to Farnell so far Andy |
23rd Jul 2008 5:07pm |
So what did the paint faults turn out to be. Mike
23rd Jul 2008 6:17pm |
Missed a bit on the rear tailgate and rust had started plus a scratch on the front wing Andy
23rd Jul 2008 8:06pm |
well atleast its done
Where as for me the cracked roof paint, gutter sealant and clear bobbling is normal! Mike |
23rd Jul 2008 8:19pm |
Forgot to say it is also having a complete new roof fitted as it's warped and the paint/seal on the join is cracked. Comes as a complete unit pre-painted so the dealer reckons it's an easy bolt-on replacement Andy
23rd Jul 2008 8:37pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Does anyone know if a new clutch fixes the transmission rattle? The dealer says they've had some with loose bolts. No sure which bit though, disc or pressure plate.
I also have an alarming "clunk" everytime I engage the clutch under load, and poor 1st to 2nd synchro, is a new clutch likely to fix those also? Although the clunk sounds more like the diff(s) to me. New clutch next Tuesday. Lets wait and see. Bosun. |
4th Aug 2008 11:07am |
Icelandy Member Since: 27 Feb 2008 Location: Hathern Posts: 54 |
Have just got mine back from the dealer today. Went in again with a reverberating noice when depressing the accelerator at high speed, they have replaced the rear differential with a new one and say this has fixed the noise.
I am going to take it for a drive down the A47 now to make sure the noise has gone before it goes to Devon 4x4 for its Icelandy transformation. If a job is worth doing.... Its worth doing well.... So get someone who knows what they are doing! |
4th Aug 2008 3:41pm |
Where did the roof warp? not along the front sloping section? Ive swopped many a defender roof on older ones - its not that much of a big deal - admittely none have been on a CSW only vans and truck cabs. Shed load of bolts in the inner gutter, bolts across the top of the windscreen obviously wires, seal and headlining remove and rear door bolts oh and trip on the xs I wouldnt want the dealer to remove the roof though it will probably leak for the rest of time - im wondering if thats what they will do with mine - if/when lr get on to this section of my claim Mike |
4th Aug 2008 4:10pm |
Regarding the roof. I'd be inclined to live with it if it's not leaking, rather than have the dealer fit a new one, especially if it looks OK inside. There seems to be a knack to fitting/refitting trim, and dealers just don't seem to have it. I guess the guy's at Lode Lane that fit it every day, get used to it's little foibles, whereas dealer fitters don't. I'd also be inclined to concentrate on the mechanical gremlins, there seem to be enough of them to keep anyone busy. Shame, as I thought this Defender was going to be the dogs doo dahs.
Bosun. |
5th Aug 2008 6:04am |
The Badger Member Since: 04 Aug 2008 Location: London ish Posts: 7 |
Ok, so I have the same problem, I can tell you a few things on the 07 that clonk are are not this clutch noise:
• If you get a clonk noise on over run as you are accelerating and shifting between gears it is the exhaust hitting the hand brake drum. I know this because I have replaced my drum brake with an X-Brake and now it does not happen. Had to remove the exhaust to remove the drum because it was that bloody close. On the clutch noise though, put the sucker in first and let it crawl sounds like a bag of spanners in the clutch. Press the clutch down fully, and let it up, right at the top of the clutch you get this rattle. This only happens when the engine is running though, if it is off you do not get the rattle. I crawled under it and let my mate try it just so I could locate exactly where the noise is coming from and it is pretty much exactly where the clutch is? |
5th Aug 2008 4:07pm |
It's back in the dealers this week for further investigation, will let you know what they come up with. Andy
5th Aug 2008 4:23pm |
DefenderKen Member Since: 09 Aug 2008 Location: Northumberland Posts: 15 |
CFB - Interested in your clutch problem, did the dealer fix it i.e. was it a binding handbrake?
Back from a 1200 mile tour of Scotland and after long runs in 6th when coming to a halt I'm getting the clattering noise as it comes to rest. Will speak to dealer next week but as this sounds like the exact problem you had I was wondering if you were now all fixed? Ken Stornoway Grey 90 XS Focus C-Max Tdci Kawasaki ZX6R C6f |
29th Aug 2008 6:23pm |
