Home > Wheels & Tyres > Swing away wheel carrier
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
I am looking at installing a swing away wheel carrier to take the weight of the rear door as suggested by most members, however I have rear light guards attached (genuine LR ones). What make of carrier will fit / allow the wheel and door to open fully with the guards fitted? I could remove them but would need to get the holes filled, painted to match etc, etc so don't fancy removing them. Has anyone carried out such a modification?
Thanks in advance 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #289562 11th Dec 2013 6:53pm
Leenorthants
Most swingaways will clear the guards.
Post #289568 11th Dec 2013 6:59pm
Josh K
It's the "most" that worries me. I don't want to buy one and find it doesn't fit. I also can't find any pics of any defender with this set up. Would appreciate pictures. 2007 (57) Defender 90 (Sold)
Post #289573 11th Dec 2013 7:05pm
leeds
It depends on the size of the wheel/tyre combination that you are running!
Sizes up to about 33" diameter is not normally a problem.
You can control how far the door opening by adjusting position of the door check/rear door strut if need be.
Oversized tyre options are available.
Please note that most swing away wheel carriers move the spare tyre towards the offside. This allows greater access to the rear door handle and slightly better visibility through rear view mirror.
If the standard versions will not work for you we have had standard ones modified at the factory to suit customers requirements.
Brendan
Post #289584 11th Dec 2013 7:28pm
Josh K
I'm running standard 235/85/R16 on boost alloys. I've even tried a google search looking through hundreds of images but can't find a single pic anywhere on internet. For once Google has let me down Big Cry 2007 (57) Defender 90 (Sold)
Post #289587 11th Dec 2013 7:31pm
leeds
We run 255/85/16 which is 34mm bigger in overall diameter and we have no problems with it touching the lights.
I suppose there might be an issue if we allowed the rear door to 'slam open' so that the door hyper opens. Hope that makes sense.
Since we have gas struts fitted we have a habit of 'controlling' the rear door opening.
Brendan
Post #289608 11th Dec 2013 7:59pm
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I had one from Alli sports on my 110 DCPU, I did'nt have light guards, but two ladders down either side sticking out about the same. It cleared it by 3" running 285/75's. The other bonus is it bolts to the chassis so no more body work holes needed Thumbs Up
Post #289614 11th Dec 2013 8:14pm
K9F
Third best modification I did..... Thumbs Up
http://www.defender2.net/forum/topic18175....swing+away If you go through life with your head in the sand....all people will see is an ar5e!!
Post #289652 11th Dec 2013 9:42pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Just fitted the wheel carrier for safari equip and have to say it's excellent. They make them for lots of suppliers but their prices are better.
http://www.safari-equip.co.uk/shop/index.p...-2002.html
Odd website with few photo's but they are the same carrier as featured in this article.
http://www.extreme4x4.co.uk/acatalog/LRM_i...arrier.pdf
I bought mine galvanised.
Post #289664 11th Dec 2013 10:27pm
leeds
Safari Equip factory is a long way, away from us! Going the long way around they are a total of 1.8 miles away Laughing
We have used their gear for many years on our own vehicles. We have had one off gear made by Safari Equip for our own vehicles and for customers vehicles varying from water/fuel tanks, wheel carriers, steering guards and side steps etc.
4x4Overlander can supply the full range of Safari Equip products, plus proving one off specials Thumbs Up
Brendan
Post #289683 11th Dec 2013 11:09pm
You won't see much except a spare wheel from your rear view mirror with a safari-equip one, they are adjustable but not by much.
Post #289704 12th Dec 2013 7:47am
K9F
Anyone with tinted windows can see diddly squit out of the rear anyway so adding a swing away makes not a blind bit of difference.....literally. They are certainly well made with no cumbersome lever-bracket with the single pivot one anyway.
Cool Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #289718 12th Dec 2013 9:14am
leeds
Standard wheel carriers are non height adjustable and shift spare wheel to the offside.
The more expensive single pivot ones such as the Safari Equip and the Alisport/Sonic ones have two height positions, as well as shifting wheel to offside.
Moving wheel to the offside increases access to the rear door handle. Having the spare wheel higher helps with attaching trailers/caravans especially when fitted with Alko type hitches.
Rear mirror visibility is hindered by middle seat rear passenger, cargo barrier, rear door grille (with or without goodies attached to them), items in load compartment, rear window tinting, then the spare wheel helps block sight line.
Like a lot of thing it is a compromise.
Brendan
Post #289730 12th Dec 2013 9:43am
epictrail
I was surprised by the fact that rear view with the carrier / wheel mounted was still very good.
Post #289817 12th Dec 2013 3:52pm
epictrail
Must remember to focus the camera next time Rolling with laughter
Post #289818 12th Dec 2013 3:52pm
