Home > Td5 > Warm up in cold weather |
My 110 has the same characteristics as your 90 Laurie, I know that there are "blocked" portions of the radiator due to various samples of England and Wales lodging in the fins. I will one day take the rad out and clean it properly but not untill after the 28th as no doubt it will get more added to it. As an aside according to my Nanocom mine doesn't go into limp mode untill it reaches 115'C and like yours just dropping the speed, heater flat out soon brings it back.to full power.
11th Dec 2013 1:56pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
The intercooler is probably partially blocked too this would also cause a rise in engine temperature.
After my blocked radiator incident i used to use a tarp to block of the bottom 3/4 of the grille when i was likely to drive through dirty water this did,nt cause any problems with temperature when pottering around off road but did stop the rad blocking. 2005 Td5 90 XS Steve |
11th Dec 2013 2:07pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
My TDI only just gets up to temp at the end of my 24 mile commute at the moment, though I suspect I may have over-cooling issues....
but I'd rather be overly cool than too hot.....I think |
11th Dec 2013 2:32pm |
