![]() | Home > Maintenance & Modifications > The definitive wheel and tyre thread..HOW THEY LOOK |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Bump
macduff Member Since: 04 Nov 2012 Location: NE Posts: 119 ![]() ![]() |
They look like Performance TX-1 wheels made in Aus
Website here http://performancewheels.com.au/Home/Wheel...mp;Cat=4WD I recall they have a French importer who may sell to UK but I cant imagine they'd be cheap. 2023 110 P400e |
w4blue Member Since: 16 Dec 2013 Location: Cardigan Posts: 4 ![]() ![]() ![]() |
Hi to all,
New to the site and have just trawled all ten pages of this thread to try and find an answer to my wheel / tyre combo dilemma. I have just purchased some 8x16 Mach 5's with an ET10 offset to replace the standard Boost alloys on my 2008 90 hard top. Having had a few conversations about which way to jump regarding the tyres, I am almost settled on some Cooper Discoverer S/T Maxx's. The issue is...........what size???? The recommended fit to these wheels is 265/75/16 and I am told these will happily fit to the 90 without any modifications required. I have also been told this would also be the case with the 285's. (my preferred size for pure aesthetic reasons!!!) So, off I confidently go to to order the tyres and my local dealer takes a sharp intake of breath and says the 285's won't fit. (under the arch, may stick out and may be fouled by the bump stops etc etc) It seems a fair number of posters have fitted 285/75's without the need for any modifications but no one has married them up to a Mach five wheel with an ET10 offset. Help!!!! Does anyone have the definitive answer? (I know I could make this easy by going with the 265's.....) Martyn ![]() Click image to enlarge |
285s are only 20mm wider than265s so I don't think you'll have a problem
Hi Mk1,
Thanks for your reply. That was my thought too. I just do not want to take the leap and then find i've got it wrong! Martyn |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 786 ![]() ![]() ![]() |
Are Mach 5's no longer a fabricated steel wheel ![]() |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
Thanks Macduff, I've email them but I think your right. Most likely well out of my price range!! ![]() |
TombRaiderTom Member Since: 14 Dec 2007 Location: Devon Posts: 40 ![]() ![]() ![]() |
I need some help! Will BFG All terrain 285/65/16 fit on my OEM LR SVX wheels? I seem to have conflicting advice? Some say that there is no need to adjust anything on the steering system or rear arches? The 285's seems to be what Twisted fit...? Any help would be appreciated...
Hi Eddie,
Mach 5's are available in both alloy and steel. Martyn |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
I wouldn't fit that size on a 7" wide rim you could fit 265 75 16 but you may need to adjust the lock stops so they don't rub on full lock 2004 TD5 Defender 90 xs station wagon |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2655 ![]() ![]() |
took this last year..
[URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Arn't they 18's ?
They certainly fill the arch nicely ![]() |
yeah, just stumbled across the photo in my iphoto the other day and thought id share, but they are 18" on 285/65
Ragerover Member Since: 26 Dec 2013 Location: In a land far far away Posts: 145 ![]() ![]() |
Is there so lift kit fitted to this ? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
