Home > Technical > Anti Stall inc Idle Jack |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 |
I fully agree, my utility seems abit quick on steep drops(miss down hilly thingy on the D3), very scary in Tixover on steep drops and was not prepared for it. Also bust rear diff which has been replaced under warranty, how you doing at getting a 4 pin diff for yours Andrew.
Mark |
22nd Jul 2008 4:51pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
I offered to pay the difference but was then told it would affect the warranty So I am waiting for the next one to go and the toys are going out the pram. I have compiled a list of problems time in dealers ect ect and will take it from there. Having said that she has been behaving of late and is a dream to drive. So I'm hoping everything has settled down now. |
23rd Jul 2008 12:52pm |
Lets hope she behaves and the toys stay in the pram. I was thinking about fitting ARB locker but that would also affect the warranty and not sure how it would affect the TC/ABS system. I have lockers on my Merc sprinter and when they are locked the ABS system is disengaged, so not sure how it would affect the Defender.
23rd Jul 2008 12:58pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
not so keen on the 1000 r/min on the downs and in boulder strewn river beds where the vehicle jerks back and fwd. to keep reaching the 1K revs.
I also spoke to some LR Engineer in the UK via an auzie forum and he reacons no can change as it is programmed in the ECU. I will wait to hear on this form in the future as I am sure someone will find out how. James Puma 110 - gone Series III 1973 - going strong |
23rd Jul 2008 2:29pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Next time i speak to the designer or tester ill ask - tbh its been ok for me, not too quick at all.
As for an ARB - yes it would affect the warranty but my question has always been when you have tc why do you then need arb (in most situations) Mike |
23rd Jul 2008 3:52pm |
I only felt the need for an ARB locker if it is going to be stronger than the diff which is in there. Which seems to be a weakness in tough conditions and breaks when TC is doing it's stuff. Hopefully it will be a one off but I know AndrewS has had similar problems.
Lets hope the new diffs which LR are putting in are stronger. |
23rd Jul 2008 4:25pm |
But that problem would be better solved then by a better "uprated" diff? Mike |
23rd Jul 2008 4:31pm |
True any ideas to where you could get one
23rd Jul 2008 4:59pm |
Have you tried ashcrofts? Mike
23rd Jul 2008 5:39pm |
Not yet, new diff was only fitted last week and has not been off road. Will have to wait and see how it gets on. Hopefully just a one off but if it keeps happening will have to improve the situation with something stronger.
23rd Jul 2008 5:53pm |
If or when mine goes again I will be going to Kamdiffs for a 4 pin. http://www.kamdiffs.com/4_pindiffcarrier.htm
23rd Jul 2008 6:12pm |
Looks like they should easily cope with puma engine output. If it's good enough for the Army they should be good for us.
23rd Jul 2008 6:41pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
my understanding is that yes the engine is adapted for the Defender and has nice low down grunt etc.
The gearbox is also developed for the Def with a lower than std 1st to aid pulling away on road with a heavy load/trailer etc. The problem then arises when you go to low in that low 1st is too low gear ratio'd for the reasons above, hence the idle jack. This when combined with the anti stall means its hard to slow the vehicle below 1100rpm in low 1st which as shown can be a requirement. Despite that i would have still thought low 1st in a puma @1100rpm is significantly slower than a td5 in low 1st for any given gradient. All ours seem to be anyway. Ref the diff issue, left foot cadence can help resolve the issue with diff and shafts and those with ETC seem to break less diffs/shafts in my experience. i see the problem due to the torque mulitplication of having a low gear (low 1st is 33% lower than the TD5) with a 360Nm torque engine running the same diffs and shafts. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
20th Aug 2008 5:12pm |
With a poorer service schedule Mike |
20th Aug 2008 5:17pm |
