Home > Maintenance & Modifications > Knackered door/window- 5 month old 110 (Video) |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4731 |
If you remove the door card you will see a black strip that is supposed to be screwed to the door frame. Your window glass slides down into this strip. The head on the retaining screw holding the strip in place rusts and the strip comes loose.It flaps and bangs against the door when the door is closed. I did a fix by getting some duct tape, folding it around itself and placing it behind the strip. Then I ran the window up and down. This pushes the strip tight to the door and the duct tape holds it in place. No more rattles. If you have a small enough screw you could use that but make sure it is sunk enough so as not to catch the side of the glass. 1982 88" 2.25 diesel
9th Dec 2013 6:28pm |
discoed Member Since: 18 Nov 2011 Location: Yorkshire Posts: 20 |
If you worry about rattles and squeaks and leaks you will go mad. |
9th Dec 2013 6:40pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
Thanks for the tips guys. I've ordered some new trim clips and i'll have a look myself.
If there is more to be done than just a few tweaks here and there i'll leave it to the dealer, especially if there are parts to buy. |
9th Dec 2013 9:03pm |
