Home > Maintenance & Modifications > Knackered door/window- 5 month old 110 (Video)
Jim_Bean
I haven't taken the door card off yet but it sounds nasty!
MY2013 with 7000 miles on the clock. Crappy build quality AGAIN.
Watch the video with the sound on.
Post #288789 9th Dec 2013 10:30am
mk1collector
It sounds like the rod that goes to the interior opener has come out of its clip and is rattling against the metal to me. Should be an easy job I think.
Edit: or something similar needs clipping back in
Post #288793 9th Dec 2013 10:41am
Jim_Bean
Its a strange one because the door lock and central looking still work.
Post #288796 9th Dec 2013 10:42am
mk1collector
It would still work as the rod to the interior door opener is ridged-ish and doesn't move with the central locking
Post #288797 9th Dec 2013 10:44am
Jim_Bean
I was going to attempt the repairs myself but was just concerned about screwing up the warranty.
If I have a go will the dealer then get out of repairing it under warranty if I can't sort it out or it needs parts?
Post #288798 9th Dec 2013 10:46am
mk1collector
If it's still under warranty I'd leave it to the dealer so, like you say, they can't refuse the warranty at a later date.
Post #288802 9th Dec 2013 11:01am
Jim_Bean
Yep, thats my plan. Just a shame they can't see me for a couple of weeks. I was more concerned about the glass disappearing into the door, i daren't use the drivers electric window.
If you think its just a connecting rod and that I should be able to lock the doors OK then i'll leave it for them to sort out.
Thanks for the advice.
Post #288803 9th Dec 2013 11:04am
mk1collector
Thumbs Up
Post #288810 9th Dec 2013 11:47am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Mines had just the same rattle for about a year now - just thought it's something that's become unclipped, and I'd get around to it someday...
So the good new is you probably won't loose the glass (as I haven't - yet)!
Bit reluctant to take the card off in case I break anything, - anyone got advice/instructions on door card removal?
Post #288811 9th Dec 2013 11:49am
mk1collector
Try and buy a trim removal tool/trim fork and just work around the door card slowly prizing it away from the door frame (after all screws have been removed) do not be tempted to rush!
Post #288816 9th Dec 2013 12:19pm
jimbob7
IMO I'd fix it my self.It can be a slippery slope leaving dealers to fix faults,do it your self and do it properly,with a bit of care it's easy enough to take a door card off and you wont be without a vehicle for a day/week.You may have to buy the relevant door card clips not unusual for some of them to break. Pov.spec,ftw. 2006, 110,TD5.
Post #288826 9th Dec 2013 12:57pm
Ads90
Thanks - if a clip on the card were to break, are they replaceable?
I.e. are they the xmas-tree type, that somehow clip into the card, that one should get spares of before attempting?
Edit - looks like Jim was typing same time - are they a dealer only item?
BTW - I tend to agree with Jim's point - small jobs are best dealt with yourself (even if the principle goes against the grain). I've had minor issues come back with more than I started with when dealers attempt to remove trim items!
Post #288828 9th Dec 2013 1:00pm
jimbob7
I bought clips similar to these,altho still not fitted the ones I broke,lol.
Don't be surprised if you breaka few even using a trim removal tool,if you have manual window winders you need a hook of some sorts to remove the circlip/handle,other than that it's straight forward.
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...3a7d82d5b3 Pov.spec,ftw. 2006, 110,TD5.
Post #288844 9th Dec 2013 1:36pm
Ads90
Thanks Jim - just ordered - then I have no excuse for not getting on with it!
Post #288846 9th Dec 2013 2:00pm
munch90
I could never be botherd to take it back and wait weeks for 10min job .. to be honest I don't trust dealers.. your better of with independent garages
mine had same noise . bolts loose where glass bolts to regulator, worth checking .. I left mine for awhile then had to do it when glass dropped down inside door (done it myself)
Post #288849 9th Dec 2013 2:17pm
