Home > Wheels & Tyres > Spare wheel relocation
Mr Baldylocks
United Kingdom 2002 Defender 90 Td5 CSW Bonatti Grey
Afternoon All
I've got a TD5 90 SW but I want to take the spare off the back door and put it upright on the O/S wheel box, has this been done before and what would you recommend to retain it there? My first thought was a HCPU spare retainer but I'm not sure that will work. All help or suggestions much appreciated.
Thanks for your help Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #288856 9th Dec 2013 3:58pm
Since a TD5 has the old-style (flat-top) seatboxes in the back, you could probably use (if you can find one) the spare wheel mount from a Series II, IIA, or III LWB vehicle. They had a recess in the seatbox top (the recessed panel was a seperate part rivetted into a rectangular hole), together with a bracket which fitted to the seat box upper surface and body capping to clamp the wheel. There are plenty about in breakers, but you'd probably need to do some refurbishment before fitting.
It would at least be all genuine and look the part.
Edit: See here to see what I'm on about!
Post #288868 9th Dec 2013 4:48pm
Assuming you can find one, the only problem may be that nothing wider than a 7.50 will fit in the recess. Darren
Post #288878 9th Dec 2013 5:05pm
Good point, that! Some adaptation would be required.
Post #288906 9th Dec 2013 6:42pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Is this any good? Note the nice black hood Whistle
Post #288934 9th Dec 2013 7:38pm
Mr Baldylocks
Cheers Guys
I knew somebody would know what to do Very Happy
Ginjez I thought it looked familiar, is that the wheel holder from the back of your 110DC and just a piece of right angled plating? Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #289044 10th Dec 2013 12:13am
Mountain_man
Wales
I have one of those wheel well recesses I no longer need. Freshly galvanised. Have a load of old tyres of various sizes here so can check if your size would fit. If it works for you make me an offer.
Post #289091 10th Dec 2013 10:15am
ginjez
6mm folded alloy with dc spare wheel bracket Thumbs Up
Post #289295 10th Dec 2013 10:12pm
Mr Baldylocks
Thanks for the offer Mountain_man but I think that Ginjez has hit the nail on the head with his idea. Thanks for the offer though Thumbs Up Life is one big adventure, that's why we have the vehicle for the journey.
Post #290673 15th Dec 2013 11:11pm
22900013A
The recess won't work in a 90 anyway as the bottom of it would want to be where your back wheel is! In SWb models the spare was always up against the bulkhead. What few people know is that some 109"s also had a similar layout. These are extremely rare but they used a much wider, shallower tray in the same was a series 1s used to have, so the spare could fit like in a SWB. They were designed for 9.00x16 tyres. A mate of mine happens to have one from a 1-Ton Series III project vehicle so if anyone really wanted I could get photos/measurements... 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #290747 16th Dec 2013 9:06am
That's another very good point which had completely slipped my mind!
That is very interesting, I didn't know that! Presumably only fitted on the SIII 1-ton. If you were able at some time to post (or PM) a photo, I would be interested to see it.
Thanks!
Post #290763 16th Dec 2013 10:54am
22900013A
I will see what I have in my stash but I don't have many pics, and not sure if the ones I have are any good. I have only seen it on series III 1-Tons but may have appeared on other models...? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #290943 16th Dec 2013 11:20pm
I gave away one of those wheel recess pieces the other month! (not the 109" 9.00x16 version though)
I run with 255's on the 90, so the 7.50 version wouldn't have fitted, but I was tentatively on the lookout for a second piece, so I could cut & weld them together, to make a mega-wide one (or just cut and weld in a strip) but I never got that far in the end.
Ratchet strap to the rollcage inner hoop did the trick Laughing
Post #291002 17th Dec 2013 8:59am
