![]() | Home > Maintenance & Modifications > Wipac Crystal upgrade |
ChrisD90 Member Since: 14 Aug 2013 Location: Middle Earth Posts: 71 ![]() ![]() ![]() |
I'm planning to upgrade to Wipac Crystals / Osram Nightbreakers.
Would anyone be able to confirm that this is the correct Wipac product for a MY13 Defender (It has a headlamp levelling knob if that makes any difference)? http://www.paddockspares.com/pm678-wipac-c...ralia.html Thanks ![]() Range Rover Evoque |
theorangebandit Member Since: 03 Jun 2013 Location: Stowmarket Posts: 862 ![]() |
Do it I have that exact set up and it rocks
great, thanks for confirming
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
I have this setup too .. recommended. Crystals from Paddocks and bulbs from Advanced Factors. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Wipac Crystals along with Osram Nightbreaker Unlimited bulbs are now fitted
![]() I've had them re-aligned (they didn't seem quite right) and I honestly can't believe the improvement. At a retail cost of around £50 you have to wonder why LR don't get this sorted ![]() The only downside is that they now make the standard sidelights look rubbish ![]() Range Rover Evoque |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5940 ![]() ![]() ![]() |
Did you go for the ones with the built in side lights? 1999 Defender TD5 110
Nope, didn't want any additional wiring. 2013 Defender 90 HT
Okey dokey 1999 Defender TD5 110
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Stick a set of RDX led sidelights on it - the perfect upgrade. Once again the difference will amaze you ![]() |
Thanks for that - Literally just ordered a pair, I like the original look of them
And then the indicators will look 'plain', followed by the stop/tail lamps .....
Yep, but all this fiddling with the Defender is keeping me out of the pub
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
Then the fog and reverse.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Shirty Carpet Member Since: 10 Nov 2013 Location: Essex Posts: 31 ![]() ![]() ![]() |
Can anyone confirm what the standard fitment lights are - I didn't buy my 2011MY 110 new. It has Wipac Quadoptics fitted. Are these OE?
