Home > Maintenance & Modifications > Taller cubby box |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
It would depend on several factors. The Nakatanenga box is ca. 400 x 280 x 130 mm. Now it depends on exactly what cubby box you get. Is there a removeable 'cup holder' as you will have to drill a hole to access the hidden lock. Brendan |
1st Dec 2013 8:30pm |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 |
These are the cubbies from "barebox". Ive got one and 2 of the rear boxes fitted. Sturdy, cheap and you could mod it to make it fancy etc. I just wanted something i could hose off! http://www.barebox.co.uk/boxes.html |
2nd Dec 2013 9:20am |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 |
I put some pieces of wood under mine so that it is about the same height as the door (where my right elbow rests). Combined with moving the handbrake, out of the way, I now greenlane in an armchair position!
Click image to enlarge Note the switches that I moved off of the dashboard so that the double DIN could fit. The window lift switches are now in a better position that before. You don't have to take your elbow off the cubby box to open a window. Yes I know, I'm a lazy driver. Merlin |
3rd Dec 2013 2:28pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
The cup holder is removable (and trimmed underneath ) |
3rd Dec 2013 3:31pm |
