Home > Maintenance & Modifications > Taller cubby box
Page 1 of 3 123>
J the tree
United Kingdom 2004 Defender 110 Other XS DCPU Auto Epsom Green
Taller cubby box
I'm looking for a taller cubby box to fit in my 110 double cab - ideally it needs to be roughly 400 to 450 mm high to rest my arm on, measured from the top of the seat box.
If they don't exist,this may be a business opportunity for someone as I'm finding the defender quite comfortable to drive Shocked but like everything there is room for improvement
Post #285892 28th Nov 2013 9:02am
That is approx 6" higher than standard.
We have a variety of cubby boxes available on our website including padded lid ones but none are that high, I presume your seats are lifted ?
I would suggest the best way to acheive that extra height is to place blocks underneath a cubby.
We supply blocks with our steel range and could put an additional set in if you wanted to go that route.
http://www.farrowsclassics.co.uk/Cubby-boxes.html
Post #285899 28th Nov 2013 9:21am
JT .. do a search on undercubby box Thumbs Up
Post #285903 28th Nov 2013 9:49am
leeds
Various options are available from using blocks underneath which will lift a cubby box about 25mm.
Safari Equipe do two different heights of padding on top of their cubby box.
If you need to lift cubby box even higher consider something like a GMB electrical box which can lift the cubby box 100 or 140mm depending on model chosen.
Another option is the Nakatanenga security box which will raise the cubby box about 130mm
Another probably more expensive option is to see a sheet metal fabricator and have one specially made to your design.
Brendan
Post #285905 28th Nov 2013 9:52am
JSG
Mobile Storage Systems do a good higher cubby box - I've always used them.
Another option is an under cubby storage area / safe which lifts the standard one up to a better height. Thumbs Up John
2011 Tdci 110 CSW XS
Post #285969 28th Nov 2013 1:42pm
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Agree with John, his looks great.
I purchased the Front Runner version which is at a good price.
drops straight in and lifts the cubby box by 50mm.
i left the spacers under the box on to get the height.
Now can rest my arm and is almost level with the gearstick.
Great on long drives and gives hidden storage locked away. Thumbs Up
Wayne 110XS CSW TD5.
Post #285992 28th Nov 2013 3:06pm
Killer90
Site Sponsor
I use nylon spacers on all my conversions now mainly to allow air flow for the amp underneath buts its great to raise the box up to act as a arm rest, combined with the two inch padding on top of my cubby box its lovely in my 90 Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #285995 28th Nov 2013 3:17pm
J the tree
Some great suggestions so far, never thought about getting a better quantity than standard box and raising it up and using the extra pace underneath.
Will have a good look at the options that have been pointed out to me and decide which is the most comfy option to go with the puma leather seats that I've just got hold of Thumbs Up
Post #286017 28th Nov 2013 3:56pm
excossack
Or make your own ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #286032 28th Nov 2013 5:21pm
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
Re: Taller cubby box
I was planning to simply make a tailored cushion to sit on the top of my cubby box. I then have the option to use it or have extra room when flaying arms are needed {!}.
Also, I like the convenience of the open tray AND the cubby box - so I modified one of each to end up with this:- [the box sits further back - no bulkhead]
Post #286033 28th Nov 2013 5:26pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
These turn up on ebay not sure where they originally come from but there great for storage. Just need to get it trimmed to make it a little more comfy.
Post #286102 28th Nov 2013 8:53pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
I don't think an underbid is possible for a puma as it will catch the Lo range gear stick
Post #286167 29th Nov 2013 12:00am
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
I shall get PJ to show the pics of how he did his, it's rather clever, and I might steel the idea myself eventually. 1998 110 300Tdi White Hard Top
Post #286185 29th Nov 2013 7:55am
In my DC I made a simple underbox which fits between the cubby and the seat base raising the cubby by about 3" at the front and 4" at the rear, primarily to accomodate a sub. It does make the cubby a much more comfortable height. The cubby is also moved backwards on the underbox to allow access to the gear levers and to prevent the gear levers hitting my coffee mug.
The underbox is made from MDF and wood and cevered in black vinyl to match the cubby, and few people actually even notice it is there.
Post #286188 29th Nov 2013 8:12am
K9F
I fitted an undercubby box, took the rails off under the cubby and had a retrim. 6ft tall and it's the perfect place for 'elbow resting.' Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #286193 29th Nov 2013 8:45am
Page 1 of 3 123>
