Home > Technical > Beeping when pressing the brake pedal? |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2641 |
I have done a search but nothing turned up on this site,
on another site it suggested that this was an indicator that the pads were running low, fronts got done about 6 weeks ago, ive just popped the rear wheels off and there is about a cm on each pad left... anyone got any ideas? |
30th Nov 2013 7:06pm |
electrical id say.
30th Nov 2013 11:39pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
Have you checked the brake fluid level? $W33T $0U7H3RN $UG4R
30th Nov 2013 11:43pm |
topped up not so long ago as had problems with the hand brake warning light ..
30th Nov 2013 11:52pm |
Perhaps that may be an associated issue then, I've had brake pads quite worn and had nothing beep. Having said that if yours is an XS that might well make a difference as mine is a County. $W33T $0U7H3RN $UG4R
1st Dec 2013 12:02am |
mines also a county, need to change that..
1st Dec 2013 12:04am |
