Home > Technical > Beeping when pressing the brake pedal?
Likeomg
I have done a search but nothing turned up on this site,
on another site it suggested that this was an indicator that the pads were running low, fronts got done about 6 weeks ago, ive just popped the rear wheels off and there is about a cm on each pad left...
anyone got any ideas?
Post #286604 30th Nov 2013 7:06pm
GUM97
What sort of beeping? An electrical beeping... Or...? An engine to TDi for!
Post #286632 30th Nov 2013 9:16pm
Likeomg
electrical id say.
Post #286673 30th Nov 2013 11:39pm
Have you checked the brake fluid level? $W33T $0U7H3RN $UG4R
Post #286674 30th Nov 2013 11:43pm
Likeomg
topped up not so long ago as had problems with the hand brake warning light ..
Post #286676 30th Nov 2013 11:52pm
Perhaps that may be an associated issue then, I've had brake pads quite worn and had nothing beep. Having said that if yours is an XS that might well make a difference as mine is a County. $W33T $0U7H3RN $UG4R
Post #286677 1st Dec 2013 12:02am
Likeomg
mines also a county, need to change that..
Post #286678 1st Dec 2013 12:04am
