Home > Puma (Tdci) > engine light
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
engine light
hi all,
Filled up tonight with shell v power diesel (only because i had a voucher!). Had about 1/4 tank of normal shell diesel left. Didn't brim it but nearly fully topped up. Pulled out of garage and noticed the engine light was on.
Anyone any ideas? Maybe engine 'adjusting' itself? Have done the same before on the odd occasion with no issue but have to admit it did feel like a bit of power had disappeared.
cheers
Churchy
ps forgot to mention that since filling it up it stopped doing the tick tick tick on turn off.
Post #286131 28th Nov 2013 9:52pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi there, Sounds like the EGR valve has given up the ghost which would bring on the mil light and also put the engine down on power. There should be several threads on this if you do a search as its a common Puma fault. The valve can be removed and cleaned to get it working again if it has sooted up or will need replaced otherwise.Hope this helps! Filling up with V power is just a coincidence I think!
Post #286138 28th Nov 2013 10:15pm
K9F
From a similar thread....Do a search and put 'p1103' in the search box. Thumbs Up
K9F wrote:
A Mass Air Flow fault will throw up a MIL light and drive perfectly well! It is usually accompanied with a P1103 code if you have a reader! It states Mass Air Flow either high or low but still within limits! In this instance the MIL light will extinguish after a few driving cycles and the fault will be logged in your ECU! Nothing to worry about as it is effectively a nuisance fault!
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #286148 28th Nov 2013 10:41pm
As above in my experience don't be hasty. See how long it stays on and if possible count the start up cycles until it extinguishes.
It's worth bearing in mind EGR readings can affect MAF readings too.
As K9F mentions however it's probably a nuiscence fault code iluminating the MIL which will go off.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #286152 28th Nov 2013 10:50pm
churchy
Diagnostics show defective egr solenoid. Also during the routine service I have been advised to replace idlers, tensioner and belts. Oh joy just before Christmas!
Normal for mileage of 106k ish?
Post #290175 13th Dec 2013 7:58pm
steve E
Wales
got in the truck this morning
started it up and engine light on.
was driving fine last night with no engine light on
any ideas,things to check before I phone LR assistance
many thanks
Steve
Post #310172 21st Feb 2014 8:44am
110 John
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Orkney Grey
Use a OBD diagnostics set if you have one to see what the fault is
Post #310182 21st Feb 2014 9:20am
K9F
As above if it is a nuisance code like the P1103 it will reset automatically after a few driving cycles. If the truck's running fine just stay local if possible for a couple of days or do a few runs and see what happens. You could potentially pay for a diagnostic you don't need. Alternatively if you're still under warranty (Edit* Which you obviously are) whip it in or call LR assist. Invest as stated above in an OBD fault reader.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310184 21st Feb 2014 9:22am
steve E
Wales
Thanks Mal
will it go into limp mode or something if theres something wrong?
steve
Post #310186 21st Feb 2014 9:26am
K9F
Not necessarily. For example the EGR P1103 is "Mass Air Flow Sensor In Range But Higher Than Expected" this will put on a MIL light but no limp mode and reset automatically, P1102 at the other end of the scale will do exactly the same and is "Mass Air Flow Sensor In Range But Lower Than Expected" there are numerous codes such as these that I call 'nuisance codes' as there is nothing really wrong but it puts on a worrying MIL light for no real reason. As you are under warranty and if you have the time and have your truck with you at work give LR Assist a ring and Mr AA man will sort you out.
After certain modifications I used to suffer this issue on a regular basis and bought a Scangauge so I could read and reset it. With an EGR off upgrade it is now a thing of the past for me.
Being under Warranty is really a no brainer as it will cost you nowt to get it sorted but perhaps a small inconvenience of a phonecall and about 10 minutes of diagnosis time if this is indeed the issue here. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310191 21st Feb 2014 9:40am
steve E
Wales
A big thanks Mal Thumbs Up
will get them out to check it over in the morning.
didn't drive it to work as worried when I sore the light on and took it home.
your help as always is much appreciated
Steve
Post #310199 21st Feb 2014 10:00am
110 John
Ive had the Air mass flow meter come up on mine recentley just reset with my OBD reader High Flow as said its just a nuisance if it is that ofcourse but allways better to get it checked dont you know any mechanics they will have one and check it for free
Post #310202 21st Feb 2014 10:02am
K9F
No worries Steve E,
Let us know what is found, it's always good to have feedback..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310211 21st Feb 2014 10:34am
steve E
Wales
Thanks again guys for the help yesterday.
Got home early to call out the LR assist and started the truck up and low and behold
No bloody light came on.
Just been out on 12 mile run and still no light.
The defender gods must of heard me yesterday.
See what happens over the next few days.
Post #310538 22nd Feb 2014 11:26am
K9F
Looks like the case to me. Nothing to worry about..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #310547 22nd Feb 2014 12:05pm
